2001 Drivers Door Latch
Old 06 Apr 2014, 03:07 pm
Default 2001 Drivers Door Latch
Seems like the electric solenoid is toasted on the drivers front door on our 2001 PT Limited. Two questions: can somebody let me know what the part number is that I need, and 2nd, where's a good place to buy one?
I'm seen some on eBay but they say 2006, and I'm not sure if 2006 will work in a 2001 and I would assume the left and right sides are different part numbers?
Thanks!
Old 06 Apr 2014, 03:27 pm
randyincctx's Avatar
Post Re: 2001 Drivers Door Latch
At least according to Factory Chrysler Parts,the drivers door latch w/Ajar Switch (After 4-10-99)-"LOCKS - POWER AUTO CENT"Radio - AM/FM" LOCKING" is specific for 2001 models....I'm not sure,but it looks similar to most others I've seen even on some Dodge,Jeep,Plymouth,and even Mitsubishi/Eagle brands vehicles within the 2001-2010 range.
The part number is #5027958AB:
LATCH. Right. Front Door. 2001 CHRYSLER PT CRUISER # 05027958AB
Here is one listed on Ebay also: New Mopar 5027958AB Latch | eBay
Just curious,but have you checked the connector for voltage,and the switch for continuity with a multimeter?
Aka:~KILLER~
Old 06 Apr 2014, 03:49 pm
Default Re: 2001 Drivers Door Latch
Thanks for the links. Is this for the Right Front door only, or will it also work on the driver's front door?
The switch semi-works and causes the alarm to go off unless I lock/unlock with the rear hatch keyswitch.
I assume the switch is also a part of this assembly, or is it a separate item?
Old 06 Apr 2014, 05:47 pm
Red face Re: 2001 Drivers Door Latch
Ooops,my bad....This is the one for the 'drivers' door,it costs a little more because it has the master power lock control(& alarm?):LATCH. Left. Front Door. 2001 CHRYSLER PT CRUISER # 05027959AB
Yeah...Latch & Switch are 1 assembly.
Aka:~KILLER~
Old 06 Apr 2014, 08:16 pm
Thanks for the link buddy! Keep on a Crusin'
Rear Door Latch Help DJStorm Tech & Performance Forum 1 19 Jul 2013 07:37 pm
Help! Rear driver side door will not latch! nobodysfool55 General PT Cruiser Discussions 7 17 Feb 2011 09:17 am
Link/Rod: Front LH Door Lock Cylinder to Latch gashog Classifieds: Want To Buy 0 13 Oct 2010 06:43 pm
I need a drivers door DuanefromPA The Detail Shop 8 21 Jun 2010 12:38 pm
PT CRUISER RH & LH FRONT DOOR LATCH LOCK ACTUATOR G56 c13ckb Classifieds: Want To Buy 2 27 Dec 2009 07:28 am
