Not starting
Old 06 Apr 2014, 09:07 pm
Default Not starting
06 PT Cruiser , 80K miles
When I start it just clicks not starting
1. Tried jump start , no luck
2. WHen I put key all light comes up, even Air starts
3. On dash get check engine light on
4. Tried on / off 3 times no code
5. Tried starting in nuetral , no luck
Have to try hammering started tomorrow, But I dont know where its located.
Thanks
Sunny
Old 07 Apr 2014, 07:04 am
Default Re: Not starting
Does anyone have picture of the 06 PT starter location.
I want to try hammer it & start !
regards
Old 07 Apr 2014, 08:06 am
Danny7627's Avatar
This may help. I have an 07 and the starter hasn't been moved for second generation PT's... good luck.
starter replacement
2008 Convertible Turbo -lite
2007 Touring N/A Boneyard
Old 07 Apr 2014, 08:10 am
Danny , Thanks . I also replace Camshaft in 2011 but did not replace magnet inside , could that be the issue ?
Old 07 Apr 2014, 08:23 am
Danny7627's Avatar
I would be out of league answering that one.
Guys like Cruzin, Randy, Nitro, Busted, Handy and others...These are wrenchers on the forum and their posts have helped me through a number of issues with the car.
Hopefully, one of them will log on the forum and give you guidance...
Danny
Old 07 Apr 2014, 11:21 am
cruserdad1976's Avatar
in a word No the sensors will keep a car from starting but not from tuyrning over
When you jump it does it ever try to turn over????
have you checked the terminals to make sure they are clean and tight???
also check the lead that is attached to the starter which is in a Horrable place to get at
the netural switch was another option but you already did that Im guessing it a auto??
Old 07 Apr 2014, 12:23 pm
Thanks cruserdad1976 , But I dont know where the starter is located !!
Old 07 Apr 2014, 12:38 pm
pop the hood. look down between the radiator fan and engine about a foot left of the battery towards the bottom. use a flashlight if you're not outside. follow the wiring harness from the positive side of the battery. you should be able to see it.
2016 Kia Soul Plus Black
Old 07 Apr 2014, 12:40 pm
Thanks will search for it when I get home.
Sunny
Old 07 Apr 2014, 01:26 pm
02 Not Starting jpcruz Tech & Performance Forum 7 29 May 2012 07:59 pm
Cranking but not starting. SiRPt3 Tech & Performance Forum 2 23 Dec 2010 10:00 pm
Looking for starting help bluesanity General PT Cruiser Discussions 3 20 Mar 2010 12:16 pm
'03 Not starting GunnerIke Tech & Performance Forum 6 29 Oct 2009 09:55 am
Just Starting air4cefamily General PT Cruiser Discussions 3 29 Mar 2008 08:41 pm
