2005 Pt cruiser cuts off please help me
Old 07 Apr 2014, 09:28 am
Default 2005 Pt cruiser cuts off please help me
My pt cruiser cuts off when I come to a stop, it idles then cuts off, otherwise it runs great while im driving, does anyone know what could be the problem?
Old 07 Apr 2014, 01:21 pm
Default Re: 2005 Pt cruiser cuts off please help me
What PT do you have (turbo/non-turbo)? What mileage? What have you done to solve the problem yourself? Has any work been done to the car that might have something to do with your problem? Is the engine light on to say that the computer recognizes a fault? Have you kept up with routine maintenance? Did the problem just start and coming to the forum is the first thing you've done?
Old 07 Apr 2014, 02:20 pm
I had very similar symptoms.
I also have a thread going... try some of the things i did, and it may help.
Heres the link:
WILL NOT IDLE PLEASE HELP
Hope this helps
Old 08 Apr 2014, 02:40 pm
I would check your vacuum hoses sounds like you may have a big vacuum leak and the car won't idle. Have someone give it enough gas to keep the engine running and listen for a hissing sound. If you can get it to idle spray the vacuum hoses with carb cleaner and see if there is a change in idle speed.
Mike
Car Cuts Out Fk5 General PT Cruiser Discussions 2 28 Dec 2012 01:42 pm
Cuts out at 2200 RPM's addition413 Tech & Performance Forum 6 16 Nov 2010 06:16 am
2001, auto, PT Cruiser, misfire, cuts out, stops tiredmom888 Tech & Performance Forum 1 30 Nov 2008 05:06 pm
Engine cuts in and out at 2200 RPM tomrinsb Tech & Performance Forum 21 13 Oct 2008 04:50 pm
Daimler Chrysler cuts price of 2005 PT frances PT Cruiser News and Rumors 4 27 Aug 2004 06:44 pm
