Changed front Struts
Like Tree2Likes
  • 2 Post By Busted_PT
Old 08 Apr 2014, 02:35 pm
Talking Changed front Struts
Just changed my front strut assemblies on my 03 Pt Cruiser Limited ...rides like new sits a little higher, but after 107,000 it was past time ...best of all it was only 200$ for both from Oreielly for Monroe struts this was complete with new springs. Took about 2 hrs to to it well worth the time and effort
Old 08 Apr 2014, 03:17 pm
cruserdad1976's Avatar
Default Re: Changed front Struts
did you do it??? did they rent you a spring compressor
Old 08 Apr 2014, 05:45 pm
I believe he used the complete assembly.
Old 08 Apr 2014, 06:54 pm
Hope you got an alignment when you were done.
Old 08 Apr 2014, 07:51 pm
Actually, without adjuster bolts in the struts. No reason to do one for struts. Anything affected by the strut change is unadjustable.
mityqwik and randyincctx like this.
Old 08 Apr 2014, 08:44 pm
Stop stirring up trouble busted, think of crewzin
Old 08 Apr 2014, 08:59 pm
HaaaaaaaaaaaaaaaaaaaHaaaaaaaaaaaaaaaaaahahahah!:ro fl:
Old 10 Apr 2014, 09:06 am
These were complete assemblies . Best of all no alignment needed knock out two lower bolts, remove 3 nuts on shock tower remove grd strap(if it still is attached) pry out knucke from botton of strut remove old strut. Hardest part was putting 2 lower bolts in place used a long drift ti alighn and it went back toghether like butter . The 2 lower bolts are not exentric type bolts so no alignment required per the Haynes manual.
Old 10 Apr 2014, 09:29 am
I didn't know that.
I had alignment done on mine - but probably needed it anyway as it had been a while since last alignment.
Old 10 Apr 2014, 11:32 am
rckstein's Avatar
I changed my own struts, too, a couple of months ago, it was a breeze using the complete assemblies. The dealership wanted an enoumous amount for labor, but that's because they price it out replacing all the parts separately rather than using complete, ready to install assemblies. I did have an alignment done because after I replaced the struts, I had the dealership replace the complete lower control arm assemblies, so of course an alignment would be needed after that, but I saved about $400 by doing the struts myself.
changed the front wheel bearing today rob342 Wheels, Tires, Suspension 2 07 Aug 2012 05:56 pm
Front struts question ptal Wheels, Tires, Suspension 18 08 Jan 2012 08:02 pm
Front Struts djpadko Classifieds: Want To Buy 1 05 Jul 2009 05:30 pm
KW front lowering struts// $200 obo DEBO Classifieds: For Sale/Trade 2 07 Apr 2009 10:58 am
front air struts for sale! pt sold Classifieds: For Sale/Trade 0 07 Feb 2006 02:40 am
