Need help or idea with a problem
Old 12 Apr 2014, 11:31 am
Exclamation Need help or idea with a problem
Hey all,
I have a 06 2.4 turbo and the other night I was driving and my battery light came on. Never seen that before. I park my car and shut it off and go to the store and come back out and it won't turn over just a click. After trying to get a jump I didn't not succeed and my starter stopped clicking aswell. Also this car came with a kill switch that runs from the ignition to the starter. Can that be a problem. My car won't turn on now. So before I start tearing it down tomorrow I wanted a better idea and I've tried replacing it with a new battery but did me no good. Any thoughts?
Old 12 Apr 2014, 12:10 pm
boonie2's Avatar
Default Re: Need help or idea with a problem
Curious why it has a "Kill Switch" ? if it was for security , the car wont run without a chipped key matched to the computer anyway..
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 12 Apr 2014, 01:11 pm
Yea I noticed the wired coming from there dash straight to the starter and cut one day and found out it was a kill switch and then had to crimp it back together again.
Old 12 Apr 2014, 02:05 pm
randyincctx's Avatar
Cool Re: Need help or idea with a problem
Start with the simple things first....
Make sure ALL connections are clean & tight(terminals,fender ground,starter contacts,etc.).
Then check cables for resistance(Ohms) with a mulitmeter,if there's too much...Replace the cable(s) as needed.
If your PT is equipped with factory fog lights,your MFS may be faulty,and causing a parasitic draw.
May also need to load test your 'new' battery(can't hurt to check).
Next thing would be to check the alternator for output @ idle(14V +/-?)
If those are all working correctly......It could be a problem with voltage regulation,and the bad news is<drum roll>.....The voltage regulator is an integral part of the TIPM,and if that's the case,the TIPM itself will need replacing.
But,check ALL of the things I've listed,in that order(more or less!) FIRST!
Aka:~KILLER~
Tags
battery, help please, killswitch, starter
Good Idea/Bad Idea 05PTGT General Turbo Discussions 6 14 Oct 2010 07:09 pm
a new idea sweetest_gurl2007 Exterior & Interior Styling 14 08 Nov 2009 10:00 pm
need help or idea on what is gone bad financethis General PT Cruiser Discussions 3 11 May 2009 01:30 pm
New idea TBURG PTS Interior Accessories Forum 13 22 Dec 2003 06:48 pm
New Mod idea turbomangt General PT Cruiser Discussions 10 03 Feb 2003 10:50 am
