Much needed help about instrumental cluster
Like Tree2Likes
Old 15 Apr 2014, 07:31 pm
Angry Much needed help about instrumental cluster
So I did a check engine light reset on my 2003 pt cruiser. Which I took off the negative cable then the positive and turned the lights on for 5 mins. Then turned the lights off put the positive back on then the negative. Now nothing on my instrumental cluster works, gas, oil, speedometer, mileage. . Everything else works. Please help.
Old 15 Apr 2014, 07:40 pm
Default Re: Much needed help about instrumental cluster
I guess you mean your instruments don't light up?
When you turned on/off the lights, you must've twisted the instrument panel dimmer on the stalk - turn it back on.
Old 15 Apr 2014, 07:43 pm
I thought it could have been that but it's all the way up. All fuses are good as well. Maybe a bulb?
Old 15 Apr 2014, 08:00 pm
randyincctx's Avatar
Question Re: Much needed help about instrumental cluster
May be a long shot.....Did you check the IOD fuse in the PDC?
I'm also curious about 2 other things:
#1.)Why & what were the reason for the CEL?.....What were the codes?
#2.)Is your PT equipped with factory fog lights?.....and/or any aftermarket alarm/anti-theft devices & lighting?
Aka:~KILLER~
Old 15 Apr 2014, 08:04 pm
Well i don't know much about cars. So what's the IOD and PDC fuse?
Old 15 Apr 2014, 08:05 pm
There's more than 1 bulb.
I'd play with the switch - maybe it has a dead spot.
Old 15 Apr 2014, 08:08 pm
Well I went to get my state inspection and the guy said it was a h20 sensor as to why the cel was on. It does not have aftermarket anything on it. It's from a small dealership owned by bikers lol
Old 15 Apr 2014, 09:09 pm
Post Re: Much needed help about instrumental cluster
I think you might mean O2 sensor,correct?......and your PT doesn't have fog lights?
As for the IOD fuse(Ignition Off Draw),it controls most the interior lighting,and the PDC(Power Distribution Center) is the black box looking thing located behind the air filter/box.
Here's what you need to look for(check those fuses):
Here's a better photo of the guide located on the underside of the PDC cover:
Kwiemanntx likes this.
Aka:~KILLER~
Old 15 Apr 2014, 09:39 pm
Talking Re: Much needed help about instrumental cluster
Your a life saver, THANK YOU SO MUCH . I took it out, and put it back in and everything is working. Now is it hard to replace a O2 sensor?
Old 15 Apr 2014, 09:45 pm
Handy_Cruiser's Avatar
Before you do that, you might want to check the trouble codes yourself. You can either do the "key dance" to get the codes or take it to Autozone or similar and have them read your codes for you. Make sure the code you have is really for the oxygen sensor.
Could it just be the instrument cluster? ukbeachbum General PT Cruiser Discussions 21 17 Sep 2015 08:50 pm
Will a 2nd gen cluster fit in a 1st gen? Lucas Interior Accessories Forum 9 04 Mar 2014 11:51 am
Cluster Issues?? Ghsthntr07 General PT Cruiser Discussions 5 03 Dec 2013 06:29 pm
Airbox, airbag cover, and gauge cluster cover needed cruisin03pt Classifieds: Want To Buy 5 26 Nov 2012 12:26 pm
Instrument Cluster needed PTloser Classifieds: For Sale/Trade 0 23 Jul 2002 06:42 pm
