Battery not charging, out of ideas
Old 16 Apr 2014, 10:07 am
Default Battery not charging, out of ideas
Car died while running,
Batt was bad, replaced
Not charging
All fuses good
Visual inspection of all wires good
Replaced alternator, old one tested good but meh
Still not charging only getting 11v reading
Batt light turns on in 20 seconds of starting
Going to test wires for power but out of ideas after that
Old 16 Apr 2014, 10:47 am
cruserdad1976's Avatar
Default Re: Battery not charging, out of ideas
only thing left is the computor it tell the altenator how much to send to the battery or I think ti does
Old 16 Apr 2014, 11:27 am
Further, the power train control module (PCM) reads a signal from the battery temperature sensor. If the PCM thinks the battery is getting hot, the alternator output is reduced.
From the shop manual:
"The battery temperature sensor is used to determine the battery temperature and control battery charging rate. This temperature data, along with data from monitored line voltage, is used by the PCM to vary the battery charging rate. System voltage will be higher at colder temperatures and is gradually reduced at warmer temperatures.
The sensor is located on the bottom of the battery tray, and makes contacts with the bottom of the battery."
Old 16 Apr 2014, 11:39 am
Red face Re: Battery not charging, out of ideas
SO in a small way I was almost correct????
Old 16 Apr 2014, 03:51 pm
Interesting, thanks for that info. I got a haynes manual. Ill open it up and explore the battery sensor.
Old 21 Apr 2014, 10:10 am
So, no battery temp sensor installed. Dont know that it ever had one : /
Old 21 Apr 2014, 04:38 pm
So turned out had a loose connection, tightened it and was getting 14.5v. Then this morning back down to 12v, could i have blown alternator? What will do that?
Old 21 Apr 2014, 06:25 pm
boonie2's Avatar
Maybe 14.5v was charging the batt. up until it was up to 12v .. turn all your electrical on and see what the draw is
My "old school" test for an Alt. check was to disconnect the battery while the car was running and see if it would still run .... DON'T do this unless someone else agrees that has experience with PT's and all the electronics , I Do not ...
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 21 Apr 2014, 09:27 pm
I'm told you can no longer run car with battery disconnected.
Old 22 Apr 2014, 08:51 am
No, i am having to charge the battery to be able to go anywhere in it. At work at the moment with it charging under my desk : /. Gotta do what you gotta do sometimes. My mechanic thinks the alternator is blown again, all the wires tested good previously, so this is the only thing that makes sense. When i say test good, they're getting power from one end to the other.
My question is what would keep blowing my alternators?
Tags
battery not charging
PLEASE NEED HELP DESPERATELY! BATTERY CHARGING ISSUES Gavin General PT Cruiser Discussions 6 08 Nov 2013 02:27 am
PLEASE NEED HELP DESPERATELY! BATTERY CHARGING ISSUES Gavin Welcome New PT Cruiser Members 6 08 Oct 2013 02:08 pm
Charging Issue?? Battery light on? drumrooster Tech & Performance Forum 12 18 Oct 2012 07:39 am
Seconday Battery, Charging issue, Amp, Sub Busa_Powered Sound and Security Forum 20 12 Sep 2012 03:01 pm
Charging system battery voltage DJmart Tech & Performance Forum 19 14 Sep 2011 11:26 pm
