Need help to figure out if I have a cabin filter compartment
  • 1 Post By micdhack
Old 19 Apr 2014, 04:22 pm
Default Need help to figure out if I have a cabin filter compartment
Hi there,
I manage to open up the top part and got to where the filter compartment is. I've seen a couple of videos online but still I am not entirely sure if I have a cabin filter compartment (I know for sure I have no cabin filter).
Can someone have a look at the pictures and verify If I do? Otherwise probably I will need to buy a cabin filter kit?
Old 19 Apr 2014, 05:50 pm
Danny7627's Avatar
Default Re: Need help to figure out if I have a cabin filter compartment
Originally Posted by micdhack View Post
Hi there,
It appears that you have the right location under the wiper cowl on the passenger side. However, it looks like the canister that holds the filter is missing.
Here's one on E-bay so you can see what I'm referring too.
01 05 PT Cruiser Passenger Cabin Air Filtration Canaster | eBay
Good luck
Dan
2008 Convertible Turbo -lite
2007 Touring N/A Boneyard
Old 19 Apr 2014, 06:40 pm
Handy_Cruiser's Avatar
Yep,
Read this:
Do all PTs have a cabin air filter?
Old 19 Apr 2014, 06:47 pm
I found this which includes also the cabin filter.
Amazon.com: OEM Chrysler PT Cruiser Cabin Air Filter Complete Kit 82206886: Automotive
Initially I thought that I was missing only the front part but there is a lot of empty space between that top plastic part and the water container which tells me that there is no housing the complete kit is the only way.
Has anyone had experience installing a complete kit? It looks like I'll have to remove the old one and there are just two bolts holding it in place. I have a 01 pt cruiser limited.
Old 19 Apr 2014, 07:05 pm
rcktpwrd's Avatar
you have an '01 so you need the kit. remove the splash guard and install the filter housing in it's place...
Joel
www.rcktpwrd.com
Old 19 Apr 2014, 07:49 pm
Thank you so much. I place an order and get it done. I'll try to take some photos in the process and maybe look on whether that hole down there is clean of leafs and other things. Nobody has done any work down there since the car was purchased.
Old 24 Apr 2014, 06:44 pm
Job done! I got OEM's filter that doesn't have the front part which is actually a good thing given that removing the water unit is an extra step that is best to be avoided.
rcktpwrd likes this.
Old 24 Apr 2014, 07:13 pm
rckstein's Avatar
Change your filter a year from now and you'll be surprised how dirty it gets and how much crud it stops from entering the vehicle!
Do all PTs have a cabin air filter? JenneK General PT Cruiser Discussions 21 26 Jan 2014 05:09 pm
Cabin Air Filter 01 BMans2ndchance Tech & Performance Forum 7 16 May 2012 04:25 pm
Cabin Air Filter Travis2k7 Tech & Performance Forum 25 26 Feb 2012 07:03 pm
Cabin filter discovering06 General PT Cruiser Discussions 7 27 Feb 2009 04:53 pm
cabin filter UKJ General PT Cruiser Discussions 2 22 Aug 2008 06:31 pm
