Air conditioning problem in a 2003 PT Cruiser
Old 20 Apr 2014, 11:26 pm
Default Air conditioning problem in a 2003 PT Cruiser
It has just warmed up enough here in Minnesota (65 deg) to try out the air conditioning, so I gave it a try , if it works at all it is very little , I Ran it for 20 minutes, stopped, opened the hood and looked to check the air conditioner, Well first off it cycles on and off mostly off ( I guess the clutch engaging on and off). the hose is cold but it seems to only be running for less then half the time. I put a gauge on it and it cycles up and down from under 10 lbs to 45lbs , up and down as it cycles on and off.
I'm guessing that it might not be undercharged because when it engages it goes to 45 lbs but I really don't know . Any ideas will be much appreciated.
Tags
air conditioning
Air conditioning problem 99PlyNeon General PT Cruiser Discussions 0 20 May 2012 12:17 pm
Air Conditioning Problem mdfrodolives Tech & Performance Forum 6 29 Oct 2011 06:55 am
PT Cruiser Air Conditioning Problem Carter Tech & Performance Forum 2 09 Aug 2011 07:03 am
2003 PT Cruiser A/C problem blondjenn Tech & Performance Forum 11 07 Nov 2010 02:55 pm
Air Conditioning Problem?Advice Please careyk General PT Cruiser Discussions 10 23 Sep 2009 11:18 pm
