No bright headlights?
Old 30 Apr 2014, 01:33 am
racefan22's Avatar
Default No bright headlights?
I have an issue maybe the forum can help with.
My 2003 has no bright lights. There is no change when I try to turn them on.
Any thoughts or suggestions I can try?
Old 30 Apr 2014, 01:40 am
Default Re: No bright headlights?
You ax always convert to the gen2 headlights, they are brighter
Old 30 Apr 2014, 01:45 am
podo2000's Avatar
Have you checked the fuse and relay for the high beams ?
2004 PTGT 135Kmiles
Old 30 Apr 2014, 01:58 am
racefan22's Avatar
Not yet did not realize that high beams had a separate circuit. Low beams work fine.
Old 30 Apr 2014, 06:44 am
Yup. Look under hood behind battery for fuse/relay.
Could also be the stalk switch, but try fuse/relay first - you ought yo be able to swap another relay - check #s on relay...
You didn't put in different bulbs, did you? They do sell bulbs that draw more amps....
podo2000 likes this.
Old 01 May 2014, 04:16 am
racefan22's Avatar
Thanks I'll look at that when I get the chance this weekend.
Old 01 May 2014, 12:27 pm
sanatanadharma's Avatar
High beams are protected by fuse #16 (17?), a 15 amp fuse in the under-hood PDC.
Posting in stealth will not be permitted in most threads please read the forum guidelines.
Old 10 May 2014, 03:07 am
racefan22's Avatar
Fuse checks out ok
Can't find a relay just for the high beams only one marked lights
Old 10 May 2014, 03:11 am
racefan22's Avatar
Also as far as changing bulbs goes , I don't know.
I bought the cruiser with whatever is in it. When I finally got the engine running I found out the high beams did not work.
Old 10 May 2014, 04:47 pm
rcktpwrd's Avatar
it's possible that both bulbs are just burnt out...
Joel
www.rcktpwrd.com
Headlights getting bright when stepping on brakes 2003 PT Cruiser lomodus General PT Cruiser Discussions 4 15 Feb 2012 08:56 am
Not that bright :-) reo816 Tech & Performance Forum 6 21 May 2011 09:11 pm
Headlights dim and bright at idle...help! The13bats Tech & Performance Forum 3 15 Dec 2010 12:52 pm
