Electrical load
Old 30 Apr 2014, 01:46 am
Crid's Avatar
Default Electrical load
Hi all
Looking for a lil help/advice recently I installed a new set of 8k hids which run off there own relay and fuse harness. And when I turn them on does t matter when, my radio and my gauge pod shut off and come back on. It only happens once after that I can turn em on as many times as I want with no issues. I have checked the ground wire on the harness and it is securely fastened to the battery. Does anyone no what my issue could be?
O mind you if I turn on headlights before starting the car there is no issue
Thanks
Corey
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 30 Apr 2014, 06:47 am
Default Re: Electrical load
I see you have an 06 - that is the first year with the Canbus electrical system.
You may have to live with it.
Old 30 Apr 2014, 12:15 pm
Crid's Avatar
Ok so that's just normal? It won't short anything out.
03 misses when not under load stan6406 Tech & Performance Forum 5 15 Jan 2012 03:26 pm
electrical problem. burning electrical plug cruiserjim269 General PT Cruiser Discussions 17 03 Dec 2010 03:38 pm
Yep, just another Detail Job! Lot of Photos so may load slowly. Candyman The Detail Shop 5 01 Aug 2009 09:35 pm
Bike Rack Max Load QualityFrogMama Exterior Accessories Forum 2 20 Apr 2008 09:42 am
Gary's website won't load PTRON The Detail Shop 7 01 Jan 2004 12:42 am
