A/C reads NO Pressure, blows warm, no fan turning, no compressor kick on
Old 30 Apr 2014, 08:05 am
Default A/C reads NO Pressure, blows warm, no fan turning, no compressor kick on
Well, the title pretty much sums it up.
I was driving this morning when suddenly I noticed the a/c was not cold at all. Yesterday, it was its normal, icy self giving me relief from our Florida heat.
We put a gauge on the low side of the a/c and got a zero reading. The compressor doesn't kick on, nor does the fan motor.
It's a 2006 with almost 99K miles.
We're going to try to add a can of Freon to see if that moves the needle or does anything at all.
Any other thoughts? And please, no four letter words... (TIPM, I mean)
Old 30 Apr 2014, 08:09 am
Default Re: A/C reads NO Pressure, blows warm, no fan turning, no compressor kick on
Well, the fan not coming on MIGHT be due to the compressor not coming on, which is due to low refrigerant, so, that's a likely and cheap place to start.
You may need professional diagnosis if that fails...
Old 30 Apr 2014, 08:46 am
Default Won't take the a/c freon...
We tried to recharge the system, but nothing happens after hookup. The can isn't getting cold as it does when we recharge our truck. Can won't dispel Freon.
What else should I check? Low/high pressure switches?
Old 30 Apr 2014, 09:05 am
You have to charge it with compressor running - since it won't run, you have to short out low pressure switch to get compressor to run with can hooked up.
Old 30 Apr 2014, 09:44 am
2step's Avatar
Have you checked the fuses?? Accessory belts??
Old 30 Apr 2014, 12:22 pm
Default This Forum is AWESOME!
Thanks to all who offered advise... we got the car fixed and cold again. It was.... drum roll.. the low pressure switch. Less than twenty bucks and we're good again. Did the paperclip jump and it kicked on the compressor. Gave it a little more Freon and it's back to chillin' in the Fla. sun.
Old 30 Apr 2014, 12:54 pm
Well, that's great! And thanks for telling us the outcome so we can stop guessing.
Old 30 Apr 2014, 02:22 pm
cruserdad1976's Avatar
AMAN thank you
Old 30 Apr 2014, 04:33 pm
Pt price wishes his could have been so cheap to fix
I don't know why I bother posting this since you won't be around to see it but why do you only come on here when you have issues?
Old 30 Apr 2014, 05:09 pm
Some people have lives away from forums - not all are like us...
A/C blows warm air klepto7 General PT Cruiser Discussions 4 20 Jun 2013 12:04 pm
Odometer reads all 8's waynemann General PT Cruiser Discussions 7 26 Jan 2012 08:16 am
AC blows warm lilredpt Tech & Performance Forum 10 19 Jul 2011 01:08 pm
A/C blows warm at idle... Travis2k7 Tech & Performance Forum 11 22 Jun 2011 08:24 pm
Turning the AC compressor off during defrost mode? DJmart General PT Cruiser Discussions 6 15 Mar 2008 10:13 pm
