Inner Fender Rot? And Tailgate Repair/advice needed
Old 03 May 2014, 06:51 pm
Default Inner Fender Rot? And Tailgate Repair/advice needed
Lifted my carpet and found this. Just curious how should i proceed? this area on my parts car is good so should I cut it out and swap? How much to cut if I do? Thanks for the advice in advance
As you can see it penetrates to the outside a bit.
Heres the tailgate I am going to repair, just need ideas how to fix this.
Silver Bullet - 2001 PT Cruiser Limited, 5-Speed, 2.4 N/A, No mods yet just fixing her up slowly
Old 04 May 2014, 01:58 pm
Default Re: Inner Fender Rot? And Tailgate Repair/advice needed
Anyone? Please
Old 04 May 2014, 06:05 pm
VNT's Avatar
VNT VNT is offline
THe floor board, grind it back and prep it and paint it. Eastwoods makes some goodstuff for treating rust.
The tailgate, I would go to a boneyard and get one with no rust and have it painted.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 04 May 2014, 06:23 pm
Agree. I like Krud Kutter to stop rust and you can paint over it.
Old 04 May 2014, 08:06 pm
Ok, Thing is the rust seems to be right at the seam between the floor pan and the inner fender? Where it joins each other. Also not sure if you can see in the picture, But there is a hole that goes to the outside in that seam.
Old 04 May 2014, 08:31 pm
I can see a tiny hole - the rust on the seam doesn't look scary.
Old 04 May 2014, 08:37 pm
Clean all the rust of that metal. then use an etching primer. Use a good seam sealer. And paint it with some Rustoleum paint from all sides. That should keep the seam from getting any worse. The hatch. Well throwing good money after bad. Get a good one.
Old 06 May 2014, 06:37 pm
Thanks for the replies guys, I will try that and post pictures of how it turns out, Should I use roofing tar over it after I do what is suggested?
Engine repair or replace advice mecheng87 Tech & Performance Forum 7 07 Jan 2013 02:28 pm
Repair advice? JBK General PT Cruiser Discussions 6 24 Feb 2012 04:51 am
Vinyl Repair Help needed bamboorods General PT Cruiser Discussions 2 04 Oct 2011 12:20 am
front fender needed mills22 Classifieds: Want To Buy 0 26 Nov 2010 05:58 pm
How to help needed: 02 PT Fender Removal mtcaves Tech & Performance Forum 0 11 Mar 2008 11:35 pm
