Cooling System Problem
Old 06 May 2014, 12:56 pm
Default Cooling System Problem
Been a while but didn't get any straight answer and still on the brink of ordering a replacement radiator fan before taking it to the shop.....AC has stopped cooling, low speed fan will run the first time I turn on the AC....AC lines starts to get cold then low speed fan will not run in cycle with the compressor.....AC line stops getting cold and will not blow cold air no more.
Old 06 May 2014, 02:01 pm
cruserdad1976's Avatar
Default Re: Cooling System Problem
for about $90 bucks just change the fan
Old 06 May 2014, 05:02 pm
Since fan works, I don't think it's the fan. Some control signal to the fan seems to be missing.
Old 06 May 2014, 05:07 pm
this is the same reason that's preventing me from buying a new fan & replacing it....I could hear the compressor cyling, engaging & disengaging...it just won't keep the lines & car cool, and the low speed fan from running everytime compressor cycles.
Old 07 May 2014, 03:13 pm
Sounds like A/C is low on freon.
Old 08 May 2014, 08:18 am
Ray_Dockrey's Avatar
You keep saying the low speed is running then shutting off so I am a little confused. The fan is a two speed fan. Anytime the AC is on the high speed of the fan should run. If you can't hear it running then its a fan issue.
Old 11 May 2014, 02:33 pm
w/c fan should be cycling on & off with the compressor, wasn't it the low speed?
Old 11 May 2014, 03:58 pm
At 110,000 miles the fan is most likely kaput. If its not it will be shortly.
Here is a picture of what happens to the brushes.
Compressor will cut out on high pressure because there isn't enough air flowing through the condensor with out the hi speed fan cooling the condensor.
Will it cool driving down the highway at 60 mph?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 18 May 2014, 09:02 pm
Sorry for the late update....PT was surprisingly blowing cold air again lately but not as cold as it used to.....took it to a shop and mechanic found some small leak on the line and was recommending to have the drier replaced as well.....not sure if I would heed his advice though.
Bleeding air from cooling system bogaz Tech & Performance Forum 16 13 Apr 2016 06:44 pm
Help with cooling system!! Osufan64 Tech & Performance Forum 3 29 Oct 2013 01:09 pm
Cooling system fault swanjack Tech & Performance Forum 12 16 Feb 2011 03:21 pm
cooling system problems BeagleDad Tech & Performance Forum 6 15 May 2010 03:58 am
cooling system ? cllwyrc Tech & Performance Forum 6 25 Apr 2010 10:35 pm
