Fixing weirdly installed passenger seatbelt
Like Tree2Likes
  • 1 Post By RedLimited
  • 1 Post By randyincctx
Old 06 May 2014, 03:47 pm
Default Fixing weirdly installed passenger seatbelt
I have a passenger side seatbelt that is twisted but not in 180 degrees (that I could fix by bending the belt through the strap).
As you can see in the pictures it is just half way twisted which makes me suspect that the previous owner installed it incorrectly. I figured if I can remove the lower bolt and give it one turn on itself it would probably fix. Problem is I tried to use one of my hexagonal tip tools (don't know the proper name) but it won't budge. The bolt has a more star shape texture so I wonder If I am using the wrong tool for the job. Also, do I have to put force clockwise or counterclockwise?
I have attached pictures so that you can see what I mean about the condition that belt is in.
Old 06 May 2014, 04:46 pm
cruserdad1976's Avatar
Default Re: Fixing weirdly installed passenger seatbelt
that is not a Hex bolt it is a torqx or a star a hex will strip it out a auto parts store will sell you a indivual one
Old 06 May 2014, 05:55 pm
Agree - I'd get a socket with the tip - it'll be tough to loosen, and you'll need the leverage of a socket wrench.
Old 06 May 2014, 06:33 pm
You Might want to do it in the parking lot of the autoparts store if they offer lender tools. Advanced auto and autozone both do if you happen to have one near you. The reason is: the bolt is to be torqued to spec ( I believe 32ft/lbs). This isn't a part you want coming loose due to improper tightening, or breaking from over tightening.
Happy Fixin'
1998 Mazda 626 - looking for a new home
'01 PT cruiser limited Inferno Red- Mopar sub (Finally) stock chrome rims LED map/ dome/ trunk lights LED Footwell lights
Planned upgrades- Heated seats, 18-19" rims, chrome grille, drilled/ slotted rotors, clean up the calipers/ paint the wheel wells, 3" cat back exhaust, new spark plug wires, Speakers all around, Either new head unit or an AUX integration.
Old 11 May 2014, 02:21 am
randyincctx's Avatar
Exclamation Re: Fixing weirdly installed passenger seatbelt
Have you tried pulling the belt all the way out?.....Sometimes they can get twisted onto the take-up reel.
If you do remove any bolts for the safety-belt/s,when re-installing be sure to always torque the the bolts to 30 ft/lbs,and use Loctite-262 (blue) thread locker on the threads......Remember you are working on a safety item.
RedLimited likes this.
Aka:~KILLER~
Replace rear seatbelt stek2008 General PT Cruiser Discussions 2 10 Aug 2012 07:38 am
Passenger Armrest installed on a 2001 - help darwal61 Interior Accessories Forum 5 03 Jun 2012 06:22 am
PT Cruiser 2005 floor wet passenger and rear passenger help resane Tech & Performance Forum 6 28 Jun 2011 12:25 pm
Seatbelt issue katie04901 General PT Cruiser Discussions 0 18 May 2011 08:04 pm
Issues - Rear passenger blinker out, passenger window not working eobryant Tech & Performance Forum 0 23 Apr 2010 12:51 am
