Noises From Back of Car
Like Tree2Likes
  • 1 Post By wb2kki
  • 1 Post By Vlefaive
Old 07 May 2014, 10:45 pm
Default Noises From Back of Car
I just purchased a 2002 PT Cruiser and I am wondering about two noises from the back of the car. One is a very soft and constant high pitched whine, kind of like what a water pump with no water would produce.
The other is fairly loud rattle that I hear only when the car is idling at a stop. There is nothing in the rear storage compartments so I know it's nothing like that. I'm thinking it might be something that is lose on the undercarriage.
Any thoughts as to what might be causing these two noises?
Thanks in advance for any ideas that you may share!
--Tom
Old 07 May 2014, 11:55 pm
sanatanadharma's Avatar
Default Re: Noises From Back of Car
Regarding the rattle:
Check your spare tire mount tightness. Sometimes the plastic lens over the CHMSL (center high mount stop light) loosens and rattles under the upper interior hatch trim piece.
Posting in stealth will not be permitted in most threads please read the forum guidelines.
Old 08 May 2014, 01:15 am
I had an annoying squeak/rattle from the back of my PT when I first bought it. It turned out to be a tail light lens wasn't seated correctly.
Old 08 May 2014, 05:38 am
Rattle can also be the exhaust, loose license plate, and don't forget the jack.
As far as the whine the only motor moving part in back without the car moving is the fuel pump.
Good luck.
Mike
Old 08 May 2014, 07:20 am
Good luck.
Mike
I've also read of others who discovered the fuel hose was loose and rattling.
My hunch is motor mount and the sound is from front of car.
Old 09 May 2014, 12:23 am
Thanks for the reply. I can probably rule out the motor mounts. Two of them were broken when I bought the car and have been replaced, and the mechanic checked the others to make sure they were fine. I also had the timing belt and pulley replaced, the water pump was replaced, and the rear shocks were also replaced, along with fixing a few leaks and general tune up work. It actually runs and idles really smoothly now.
--Tom
Old 09 May 2014, 11:20 am
Vlefaive's Avatar
I always seem to get an annoying whine from the passenger side whenever the mother-in-law gets in
eightball likes this.
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Noises when braking and accelerating anna_kaa Tech & Performance Forum 2 15 Oct 2013 06:14 pm
rear end noises freekshow Tech & Performance Forum 3 07 Jul 2013 10:03 am
question about brake noises 4SPEED Tech & Performance Forum 6 25 Jun 2008 05:41 pm
Turbo noises quicksilverdon General PT Cruiser Discussions 5 05 Apr 2005 02:08 pm
SRT-4 and GT 5 speed "clunk" noises lip General Turbo Discussions 9 13 Oct 2003 07:35 pm
