Knocking over rough roads
Like Tree6Likes
  • 2 Post By CREWZIN
  • 1 Post By cruserdad1976
  • 2 Post By randyincctx
  • 1 Post By quicksilverdon
Old 11 May 2014, 09:41 am
Gub Gub is offline
Default Knocking over rough roads
I seem to have a knocking noise when going over pot holes, coming from under the car any ideas?
Thanks in advance
Old 11 May 2014, 10:31 am
Default Re: Knocking over rough roads
Lots of things in the suspension plus the exhaust area that cold cause a knocking noise. First you want to try and narrow it down to the front or back of the vehicle. Then you need to get it up on a lift to have everything checked out. If you don't know what your looking at under there, a lot of shops will do a free diagnostic/inspection for worn parts.
randyincctx and boonie2 like this.
Old 12 May 2014, 07:05 am
randyincctx's Avatar
Question Re: Knocking over rough roads
Thanks in advance
Your question is too general in description.
In order to be able to give you the best advice,you really need to try and pinpoint the source a little more for us.....For instance;Is it: Front or Rear? & Left or Right?
But,a typical source of 'klunking' from the rear end is the Watts Link & Bellcrank Assembly,and it can be checked from under the rear by firmly pulling left & right on it......If it 'klunks' it's bad!
See these for more info:
Watts-Link or Bellcrank Replacement
http://fourbarrel.com/wattslink.html
Aka:~KILLER~
Old 12 May 2014, 07:10 am
cruserdad1976's Avatar
not a lot of info but id venture a guess the watts link in the rear
randyincctx likes this.
Old 12 May 2014, 07:27 am
Lightbulb Re: Knocking over rough roads
Secondly,if your noise is coming from the front end,the first thing I'd check personally,would be the front stabilizer.......Check the mounting brackets,bushings,and end links/bushings.
Depending on the 'klunk',it could be a broken bolt for the mounting bracket.(the bolts can get pretty rusty from road salts/etc.)
For more info see these threads:rusty anti-sway bar link bolt
What's this broken wheel/suspension thingy???
Aka:~KILLER~
Old 12 May 2014, 09:06 am
Drive it up on ramps or get it on a lift and start inspecting things...
cruserdad1976 likes this.
Old 12 May 2014, 11:54 am
Gub Gub is offline
Thanks guys, sorry for being a bit vague, just really hard to tell where it's coming from when I am driving, maybe I will have to get a passenger to help me out as they can move around a bit to try and pinpoint it.
Thanks again
PT On Icy Roads? Can A Southerner Survive? Handy_Cruiser Gulf PT Forum 21 09 Dec 2013 01:41 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
New Owner in Hampton Roads, VA 04GTTurbo Welcome New PT Cruiser Members 12 14 Jun 2013 03:22 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Speedometer swings on rough roads tonganoxie pt Tech & Performance Forum 5 09 Feb 2006 08:00 pm
