Motor Mounts
  • 1 Post By NitroPT
Old 17 Jun 2014, 04:57 pm
rckstein's Avatar
Default Motor Mounts
Does anyone know what the "tab" is on the end of some of the motor mounts on the PT?
List: Engine Mount - 2006 Chrysler PT Cruiser | O'Reilly Auto Parts
On the above link, the longer mount (lower) you can see in the pics that one has a "tab" on the side of the bigger end, and one does not. What is this for? Some kind of a harmonic balancer to offset the engine vibration? I inquired at O'Reilly and they don't know, I inquired at my dealership and they don't know. If you look at the same mounts on the AutoZone website, for the one without the "tab" they have it listed for the convertible PT.
http://www.autozone.com/autozone/par.../N-jnwygZ93xoa
Old 17 Jun 2014, 05:18 pm
InfernoGT's Avatar
Default Re: Motor Mounts
Not sure. They were there on Neons too. Definitely do not need it, that's for sure lol.
2006 PTGT with 5spd. ~60k miles
Old 17 Jun 2014, 05:40 pm
rckstein's Avatar
There must be a purpose for it. See the following link for an issue that I am battling right now with a shop. In the parts manual for my PT, it lists the motor mount with the "tab" as the correct part for my vehicle. But the shop in question installed O'Reilly mounts that don't have the tab. They have installed (2) lower mounts in the past (6) months.
Shop Repairs
Old 17 Jun 2014, 05:47 pm
It is suppose to reduce vibration at idle.
I am not sure I have ever noticed a difference in the ones I replaced over the last 2 years with and with out it? Once I change and properly set up the mounts the vibration issue if it was one of the issues prior the mount change was gone?
IDK for sure?
Superman1984 likes this.
Old 13 Jul 2014, 04:53 pm
Correct It's partly to dampen the vibrations and should the mount rip so bad that the engine comes up that Tab should in theory act as a stop to keep the engine from slamming back into the firewall No BS. I've seen various other cars with them and an old timer 60+ years old told me that once when I was around 16-20 something. Do I win a prize?
Old 13 Jul 2014, 05:05 pm
The only problem with that is that the tabs can't hit anything. There is nothing close to them. So they can't restrain the engine in any way. I though it to be some kind of counter weight to help with vibration. Just a guess on my part.
Old 13 Jul 2014, 06:14 pm
rckstein's Avatar
I would go with some type of anti-vibration or counter-balance. Below is a pic of the new OEM mount recently installed on my PT. Note that the "tab" area is at the front side of the engine and this also goes for the upper mount, so the "tabs" would not make any contact with the firewall as they are on the opposite side of the engine. Also note that the "tab" on the new mount is much heftier than earlier mount versions. On the upper mount it is just a piece of metal screwed onto the mount, but this larger "tab" is actually in the casting.
Motor Mounts go-vair Turbo Performance 14 03 Apr 2017 10:50 pm
Motor Mounts PT_Panel General PT Cruiser Discussions 3 04 Aug 2013 04:35 pm
Motor Mounts Jimmy2011 Tech & Performance Forum 27 12 Mar 2012 10:35 pm
Motor mounts sdwilson Tech & Performance Forum 8 03 Aug 2010 12:49 pm
motor mounts knowyourturbo Classifieds: For Sale/Trade 1 23 Mar 2006 07:36 pm
