2001 pt cruiser pulling weird codes
Old 24 Jul 2014, 12:59 pm
Default 2001 pt cruiser pulling weird codes
Well ill start from the beginning this is my grandmas car it started out by just stalling out sometimes it'd start back up imdiatly somtimes you'd have to wait a minute after knowing this I went over with my jump pack my grandpa had already put a new posative cable and camshaft position sensor on we hooked it up to the jump pack started right up turned the jump pack off watched the voltage go down alternators out right? bring it to the shop apparently the wiring was rubbing on the cv axel and grounded car out new battery and alternator car runs fine stalls out on the way home bring it back to shop resets computer runs fine having light again bring I back to shop camshaft position sensor again replaced it runs fine now to today it's pulling weird codes like 13 plugged the scanner into another pt cruiser and it pulls real codes with the letters in the format there supposed to be just not 13 have any ideas what's going on? Any help would be greatly appreciated
Other scan tools are still pulling code 13
Old 24 Jul 2014, 03:04 pm
Default Re: 2001 pt cruiser pulling weird codes
I think the 2001's were prone to having the harness dropping an rubbing on the cv axle thereby chafing wires. happened to my wife's and Crewzin's, the head moderator here. the problem after the fact could be the sensors not being oem mopar. you didn't say if the ones you replaced were oem or bought from an auto parts store.
some will argue that it doesn't matter, but too many have had problems with aftermarket sensors.
2016 Kia Soul Plus Black
Old 24 Jul 2014, 03:27 pm
Would it not being a factory sensor cause this problem? Is it possible I grounded out the computer and damaged it when the harness grounded on cv axel ? The wires have been repaired
As of now it's pulling code 1300?
Old 24 Jul 2014, 04:20 pm
Reading over your first post I don't see that your having any problems now, just the engine (fault) light which is giving you odd codes. In our error code list, P1300 is :P1300 Ignitor Circuit, whatever that is. As soyomb said, having to replace the same two sensors, get yourself a MOPAR one.
Old 24 Jul 2014, 05:12 pm
Clearing DTC's does not correct or improve an issue.
Because you mentioned needing to jump start the PT.
The first problem to resolve would be the charging issue.
I might start considering looking at the engine and chassis ground as well the cables and their condition at the battery.
You may also consider to load test the battery. Make sure it is charged prior testing.
IMO I would change any sensor until you know that the battery is in good condition and correctly being charged when the engine is running.
My I suggest in future response to use the proper DTC code and not the number alone. This way we have more confidence in the information?
Old 24 Jul 2014, 05:19 pm
LionPT's Avatar
Originally Posted by NitroPT View Post
IMO I would'nt change any sensor until you know that the battery is in good condition and correctly being charged when the engine is running.
Fixed it
Old 24 Jul 2014, 08:34 pm
New battery and alt have been installed I still have check engine light and weird codes it starts under its own power fine now sorry if my wording was bad
Pulling my hair out- 2001 PT won't start cb316 Tech & Performance Forum 46 16 Jan 2015 03:44 am
2001 PT cruiser not firing no codes bentonggbn Tech & Performance Forum 13 19 Jul 2014 10:09 am
2001 PT Cruiser Error Codes 1193 and 0320 01cruiserproblem Tech & Performance Forum 0 06 Jun 2011 06:34 pm
2001 PT Cruiser Just Died... Got codes.. Took a cab home pasikobri Tech & Performance Forum 7 08 Feb 2010 05:02 pm
