No orafice on my A/C??????
Old 25 Jul 2014, 02:12 pm
Default No orafice on my A/C??????
My A/C has never worked all that well on my 2001. After hooking up the gauges, I have no high pressure. I have roughly the same pressure on both sides. The high side is slightly higher but not by much.
I live in the Phoenix metro area so the temps around here during the summer are well into the triple digits so I'd really like to get my A/C working as it should. Just to give you an idea, it was 116 yesterday.
After doing some research, it looks like my compressor is on the way out so I bought a new compressor and an orafice tube "kit". The kit consists of a metal tube with compression fittings and the orafice. How it works is you cut your original tube, remove the orafice, connect the new tube with the new orafice inside to your original tube and tighten the compressions fittings.
Sounds pretty easy. The existing tube is supposed to have two crimps where the orafice is to hold it in place. My tube is much shorter and has no crimps so that leads me to believe someone put the wrong tube on there. Perhaps for a later model that doesn't use the orafice????
I know it should be an easy fix. Just by a completely new tube and go from there. I'm actually thinking that since there is no orafice there, that is my problem and if I just replace the tube, recharge the system, I should be good to go.
What are your thoughts??????
One more question. If I just replace the tube, should I put more pag oil in there?
Just so you know, no I'm not venting the freon out. I have a friend that can evacuate it. He has a big truck firm and has all the stuff.
Old 25 Jul 2014, 07:32 pm
Default Re: No orafice on my A/C??????
Sounds like you should ask him. He is a pro from the sound of it. He may be a bigger help the we. Or at least me. Couldn't hurt to ask .
