Sunroof
Old 30 Jul 2014, 10:28 pm
Question Sunroof
'03 Limited 5spd N/A sunroof seems to intermittently slide back or closed when it wants to and it doesn't fully retract the edge of it all the way into the roof line. Is this normal after '01-'02 for these cars not to open completely and be somewhat slow or annoying? I also want to know should I consider looking for anything obstructing behind it, lubing the tracts, and checking the switches for it? Any help much appreciated . Thanks
Old 30 Jul 2014, 11:47 pm
Default Re: Sunroof
Tracks are aluminum and guides for the sunroof are all plastic, I cannot see dirt being the issue because the track is inside the car. I'm thinking the motor is getting weak. But make sure your battery is at least 12 volts and terminals are spotless. When I put mine back together after replacing the tracks I used a qtip to grease the track, and I only put the grease where ther was contact between the gides and track. I didn't use much.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 31 Jul 2014, 07:49 am
Default Re: Sunroof
Yes - only earliest PTs had sunroofs that opened all the way.
Old 31 Jul 2014, 08:20 am
Handy_Cruiser's Avatar
Default Re: Sunroof
Yep, just another reason the 2001 PT is so highly coveted.
Sunroof fix 1AZPT General PT Cruiser Discussions 13 26 May 2015 10:53 am
Sunroof Chrisd069 General PT Cruiser Discussions 1 01 Apr 2012 06:04 pm
Sunroof ? cllwyrc General PT Cruiser Discussions 8 11 Mar 2012 04:19 pm
sunroof HELP!!!!!!!!!! Lana Interior Accessories Forum 4 25 Sep 2006 04:38 pm
Air Dam for Sunroof hugh_mack General PT Cruiser Discussions 1 22 Nov 2002 08:38 pm
