So, where does this go..??
Old 31 Jul 2014, 11:30 pm
LionPT's Avatar
Default So, where does this go..??
I replaced my oxygen sensor again today & found this plastic bracket jammed in the cross member on the passenger side. I assume it was taken off either during the head gasket replacement or some other repair...set on the cowl & fell off.
Anyone got a guess as to where it might go..??
Old 01 Aug 2014, 12:27 am
Default Re: So, where does this go..??
Looks like the a wiring harness clamp that goes into the steel bracked that supports the intake manifold next to the fire wall. It keeps the wires from moving which as thin as they are they could break.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Aug 2014, 01:53 am
LionPT's Avatar
I know I'm missing that part. What does the big end attach to..??
Old 01 Aug 2014, 05:14 am
If you mean the "U" part I believe the wiring harness is in the plastic conduit tubeing and it. It should have a stub sticking out that goes in to a hole in the metal bracket.
I can check latter today.
73 Charger SE
01 Sebring flip
Old 01 Aug 2014, 06:59 am
LionPT's Avatar
There is no stub on it & it doesn't look like anything is broken off from what I see. It has 5 places to insert a hose/wires. The big 'U' looks like it could fit over the radiator hose.
Old 01 Aug 2014, 09:19 am
LionPT's Avatar
Here are some more pics.
Says "TRW" on 1 side & "PA66" on other.
Old 09 Aug 2014, 01:25 am
LionPT's Avatar
