Rear Wiper, No pressure on the glass? Possible spring?
Like Tree2Likes
  • 1 Post By boonie2
  • 1 Post By Flash619
Old 03 Aug 2014, 06:05 pm
Flash619's Avatar
Default Rear Wiper, No pressure on the glass? Possible spring?
Hello all,
I seem to have an issue with the rear wiper arm on my cruiser where the arm itself, has no real elasticity to it anymore. In the sense, you can move it with no force against it what so ever. It will sit at any position I put it in just fine. Due to this, the wiper blade itself, is not being forced against the glass properly.
I checked under the arm and I can see a spring, but figured I would ask here before I worked off of assumptions. So I was curious on what peoples thoughts were on this, or if anyone else has ever encountered (and overcame) this before?
Thanks a bunch!
Old 03 Aug 2014, 06:09 pm
boonie2's Avatar
Default Re: Rear Wiper, No pressure on the glass? Possible spring?
Just get a new arm at your local parts store
NitroPT likes this.
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 03 Aug 2014, 06:42 pm
Flash619's Avatar
I would if I knew how to take it off. ^^; I took the rusted nut off the back side but it appears it doesn't remove that way, and if it does, I lack the appropriate pushing tool.
I was able to fix this by spraying some penetrating fluid into the arm hinge assembly. Must have just had some rust buildup. Problem solved.
boonie2 likes this.
Old 03 Aug 2014, 07:05 pm
I used a battery terminal puller to remove the wiper arm (after taking nut off).
Old 04 Aug 2014, 04:33 am
Yeah, I've encountered that on my '01. It seems like they set the hinge pin too tight. A little penetrating oil on the hinge pin and work it has always been my "solution".
Old 04 Aug 2014, 09:22 am
Had same problem also put some penetrating on the hinge and when it is free put some lithium spray on after.
To pull it I think you will need a battery puller as said.
Good Luck!
Mike
06 PT
Old 04 Aug 2014, 09:28 pm
Samo, samo here, a little penetrating oil (and some wiggle wiggle to work it in) and your good to go
A still runnin' 01 Limited,,all with a little prayer, and a lotta elbow grease
Red tint tails, chrome trimmed grille, custom towel rack buttonless flamed shifter, auto dimming rear view, Homelink remote transmitter, driver seat drawer, MOPAR sub, lowered 1" rear, MOPAR/Borla dual tipped exhaust, chrome trimmed GT gauge/airbag surround, front 35% tint, and the ever so important Fuzzy Dice
Old 04 Aug 2014, 10:11 pm
I bent the rusty riveted area on mine open a hair with a sharp flathead screwdriver so it can move more freely. The oil was always a short term repair on mine. --Don't bend the spring to increase pressure. It will make the wiper "hop" across the glass.
Old 05 Aug 2014, 01:27 am
rockandroller's Avatar
I never found the stock wiper to have any useful pressure, and now am much happier with the performance of the 'Opal Corsa' wiper mod :-)
(And had to let the penetrating oil sit overnight, to get the rusty old nut off...)
2004 'Turbo Lite'
Tags
rear window problem, rear wiper, spring
Silver pt hatch with glass and wiper assembly server Classifieds: For Sale/Trade 1 06 May 2012 12:03 pm
Newbie needing rear glass replacement help henryj429 General PT Cruiser Discussions 1 20 Aug 2009 10:09 pm
Rear window glass without wiper hole? NMdesertracer General PT Cruiser Discussions 1 04 Apr 2009 07:54 pm
scratch on rear glass :( kevinl1058 The Detail Shop 2 22 Feb 2005 10:54 pm
R&R the rear window glass? Cal Cruzer General PT Cruiser Discussions 3 18 Nov 2004 12:26 am
