Preventative Maintenance Completed
Like Tree6Likes
  • 5 Post By Johns Steel Blue
  • 1 Post By NitroPT
Old 04 Aug 2014, 10:02 am
Johns Steel Blue's Avatar
Default Preventative Maintenance Completed
Just had major preventative done to my 2003 Limited. (80,000 Miles)(Hoping for another 80,000)
Timing Belt
Water pump
Both Belt Tenioners
Alternator Belt
Serpentine Belt
Cooling System Flush/Fluid Replacement
John
People say I have a drinking problem. I Drink... I Get Drunk... I Fall Down... No problem! ! !
Old 04 Aug 2014, 10:03 am
Default Re: Preventative Maintenance Completed
Good Job John. I'm enjoying your wet weather here in Midlothian.
Old 04 Aug 2014, 10:06 am
Hey Carey,
Yeah, been kinda wet. My dogs don't like to go out in the year when it's wet.
John
Old 04 Aug 2014, 10:07 am
If you are running with an automatic it is a good idea to do a filter and fluid change. Manual transmission just a fluid change.
Busted_PT likes this.
Old 04 Aug 2014, 02:02 pm
I assume you do oil, spark plug & wire changes more frequently???
Old 11 Aug 2014, 01:25 pm
Duh, of course..................................
John
Old 11 Aug 2014, 01:34 pm
Update to issues since the Maintenance. The day I picked up the car, the air-conditioner did not work. They called later in the day with a song and dance, etc. It worked when I brought it in so after arguing with the service manager they replaced the radiator fan. Picked it up the next day and the air worked fine. The ride home is only about 3 miles. I did not drive again for four days when I had to drive into work. (13 miles) Well, the car overheated to and from work. I had to run the heater to keep the temp in a safe range. When I got home I called and talked to the owner of the dealership. After explaining all that had happened and they had their hands on the cooling system/etc, he said they would address the issue. Apparently they damaged the radiator when installing the new fan assembly. New radiator was installed and all appears to now be working ok.
Needless to say, I will not be taking my wife's PT there when it is due for the same type maintenance.
John
Old 11 Aug 2014, 03:31 pm
harrym's Avatar
I'm glad to read that you got it taken care of.
Harry
2005 Touring n/a - Cool Vanilla with J&J vertical billet grille, PTeazer tail lights, Chrome wheels and Baby Moons.
Old 11 Aug 2014, 03:58 pm
You did say dealer?
Preventative Maintenance TallahasseeGT General Turbo Discussions 23 14 Jul 2011 11:02 am
Preventative Maintenance Questions..... Busa_Powered General PT Cruiser Discussions 11 26 Jun 2011 11:58 am
completed (for now) interior LED project Excoastie Interior Accessories Forum 5 12 Apr 2011 07:45 pm
Custom box completed! Bigphil3232 Sound and Security Forum 4 08 Jul 2004 02:47 pm
Custom box for speakers completed! Bigphil3232 General PT Cruiser Discussions 7 07 Jul 2004 07:39 pm
