rough idle on startup
Like Tree2Likes
  • 2 Post By blitterbit
Old 05 Aug 2014, 06:48 am
Default rough idle on startup
I was adding coolant to my wife's cruiser this morning. While under the hood I reseated the air filter box that was floating loose after I replaced the battery a few weeks back.
I just started the car and it revved up high upon start and then settled down to about 1500rpm idling really rough with an up and down idle.
Sounds like I may have knocked something loose (sensor?) while under the hood. It was running fine when I started the car up to pull it out of the garage.
Any ideas where to look?
It's a 2001 PT Cruiser Limited with the standard 2.4 engine.
Old 05 Aug 2014, 07:07 am
Default Re: rough idle on startup
Sounds like you pulled loose one of the vacuum lines. Look all over the engine, air filter system and at the lines from/to the brake booster to see if you can find a line that's become unattached.
Old 05 Aug 2014, 07:55 am
I suspect you may be right about the brake booster. I'm not familiar with the brake booster, but I looked in the area around the brake fluid reservoir and didn't see any loose vacuum lines. Are there any pictures of the brake booster and the lines I can look at for reference?
I started up the car and it was idling high (around 2 grand). Putting the car in gear I noticed the car wanting to move even with my foot on the brake pedal. Granted the engine was idling higher than normal, so that would add to it, but I don't think the brake pedal felt like had the power assist it should have. (I could be imagining things too. )
Old 05 Aug 2014, 08:02 am
Bake booster is back toward firewall, a "can" about 9-10" in diameter, about 3-4 inches deep.
Old 05 Aug 2014, 08:17 am
Something to read with a picture......
http://www.justanswer.com/chrysler/3...ng-brakes.html
Old 05 Aug 2014, 08:19 am
If your brake hose was off you would have no brake assist. The brake pedal would feel very hard.
I would also suspect the PCV hose if any hose was dislodged or broken?
Old 05 Aug 2014, 08:41 am
Thanks for the picture, I'll take a look.
Where is the PCV hose?
Old 05 Aug 2014, 08:51 am
Off valve cover - valve cover has the oil cap - other end goes to intake.
Old 05 Aug 2014, 04:53 pm
Found the disconnected vacuum line once I pulled the plastic cover off the top of the engine. Looks like one of the lines that runs back along the firewall towards the brake booster. Clipped off some excess and it fits nice and snug now.
Thanks guys!
Old 05 Aug 2014, 06:18 pm
Glad you found it.
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
Rough Idle 32seventeen Tech & Performance Forum 4 15 Jan 2013 10:10 am
Rough idle 03 GT elmeyer Tech & Performance Forum 2 03 Jul 2009 09:44 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
