Ignition
  • 1 Post By LionPT
Old 06 Aug 2014, 03:04 am
Default Ignition
This is a stupid question but I just bought a 2001 pt cruiser and I don't know how to take the key out of the ignition. I just turn it off and jiggle and push until it comes out.
Old 06 Aug 2014, 06:50 am
LionPT's Avatar
Default Re: Ignition
If it's an Automatic, make sure that the shift button on the top of the ball if fully out. Turn the key to Run than move the shifter to Reverse than back to Park...this will usually release key. If not, you might need to replace your ignition switch.
Old 06 Aug 2014, 10:34 am
No it's not a problem with the car I don't know how to normally take the key out, on my truck you just pull the key out, but on my moms Acura you push it in then turn it back, idk how to normally take the key out
Old 06 Aug 2014, 10:37 am
If it's automatic and the key is turned in the right direction (OFF) than the key should just pull out without any hesitation.
Old 06 Aug 2014, 10:39 am
cruserdad1976's Avatar
in my moms outback you dont take a key out but like crezwin said turn it off and pull it out
Old 06 Aug 2014, 10:55 am
Hmm I think what I've had to do is turn it off and move it up on position and push it in and it comes out. It's a 2001 automatic touring edition by the way
Old 06 Aug 2014, 11:00 am
Or I guess is the off position As far as it will go? Or not
Old 06 Aug 2014, 03:36 pm
Twisting the key all the way towards you is the accessory position - gives power to things like radio with engine off - turn one click toward front of car to OFF to remove key.
One click forward from OFF is ON - where engine runs, after you turn all the way to front of car for START.
Old 06 Aug 2014, 04:06 pm
you're pushing the button on the column by the key to release it, right?
No ignition, please help! nickcruiser General PT Cruiser Discussions 9 07 Dec 2015 04:49 pm
%#^&&* ignition key!! wompus General PT Cruiser Discussions 19 02 Aug 2013 04:57 pm
Ignition sticking... help? amgglekim General Turbo Discussions 3 03 Aug 2012 11:25 am
msd ignition oeldisplay Tech & Performance Forum 4 19 Jan 2009 05:32 pm
Ignition Key uskeith Tech & Performance Forum 7 17 May 2008 05:45 am
