Weird clunk
Like Tree2Likes
  • 2 Post By quicksilverdon
Old 08 Aug 2014, 06:01 pm
Crid's Avatar
Default Weird clunk
Hi all
My 06 na has an odd clunk in the front end that's been there for a while and I cannot pin point what it is. It happens as soon as u pull away from stop. U can't hear it but u can feel it. It lasts about 1 sec and it's gone until the next time u pull away.
Recently I have changed my lower control arms completely so I have new ball joints bushings, I have lowered it on Tien springs and has all new struts bearing plates and mounts. The only thing I can think of is maybe it's a wheel bearing starting to go. But I am unsure. I hope I have given enough info to help u. I should also state the clunk was there before lowering the pt as we'll.
Thanks In advance
Corey
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 08 Aug 2014, 06:03 pm
Default Re: Weird clunk
Motor mount or transmission mount is my guess.
rckstein and LionPT like this.
Old 08 Aug 2014, 08:31 pm
Crid's Avatar
U mean those torque struts? Those aluminum bars with rubber bushings in em?? If so I have changed then to.
Old 09 Aug 2014, 08:11 am
Did you replace the stabilizer bushings? If not check if OK they can look good but be loose use crowbar listen for noise. Was the noise there before you changed the struts are they thew correct application? Check for binding. whoever changed the bushings should have tightened them down with the full weight of the car.
After that I'm lost. Are you sure it is from the front. I was chasing a clunk in the back turned out to be in the front. Check your watts crank in the back.
Good luck.
Mike
Old 09 Aug 2014, 04:21 pm
do you still hear & feel the clunk every time you hit the pothole?
Old 09 Aug 2014, 05:42 pm
Crid's Avatar
Haven't checked the bushings but they are new last year. And as for the pot hole no I don't think it does make that sound just when I pull away from a stop
clunk clunk durango Tech & Performance Forum 11 01 Aug 2016 10:26 am
Clunk behind Dash Treedweller General PT Cruiser Discussions 6 09 Aug 2014 01:24 am
clunk in reverse wb2kki General PT Cruiser Discussions 6 23 Apr 2014 09:00 am
New LCA's and still have a clunk... Jetta02awp Wheels, Tires, Suspension 0 24 Jul 2010 07:13 pm
Strange clunk frankb Tech & Performance Forum 4 30 Nov 2009 08:10 pm
