Need guidance...no compression in cyl 3
Like Tree4Likes
  • 1 Post By NitroPT
  • 1 Post By 06OregonCruiser
  • 1 Post By JoeX
Old 10 Aug 2014, 01:59 am
Default Need guidance...no compression in cyl 3
I have 2007 Limited turbo. 173,000 miles on it.
P0303 code came up, turns out theres no or low compression in cyl 3. Mechanic said it could be piston rings, but most likely is valve.
Cost: $1100....replace valve, re-mill surface, etc. This is the 2nd time I've had valve problems and had to have head removed.
Wouldn't it make more sense to replace them all? Its seems to be inevitable that they will all go bad at some point....
I'm thinking I should buy a reman head assy. (I've seen them for around $375) and take it to a mechanic.
Will this save me money?
Any thoughts?
Old 10 Aug 2014, 02:17 am
Default Re: Need guidance...no compression in cyl 3
Have a cylinder leak down test performed to verify what is being suggested wrong with your engine.
gwairbrush likes this.
Old 11 Aug 2014, 07:46 pm
I had the same thing happen in my 06, did the leak down test and cyls 2&3 were bad. Pulled the head and sent it to the machine shop, they replaced all the exhaust valves. Cost was about $1600 (including timing belt, v belt and labor but not water pump or tensioner). I didn't see the rebuilt heads for $375 until it was too late.
'06 Cruiser Touring, 157k, Cool Vanilla, Auto
Old 12 Aug 2014, 12:13 pm
I'm thinking it might make more sense to replace the whole damn head....seems like its a grand for ever valve times how many valves do we have in these?
as it is I'm gonna need a new catalytic converter because of all the unburned fuel running thru it
Old 12 Aug 2014, 02:25 pm
I think I would've gone the $375 route if I had found them before the head got sent to the machine shop, do your research on the company offering them though. Good luck.
Old 12 Aug 2014, 05:41 pm
UptownSport's Avatar
Be careful, while the heads themselves aren't different (casting numbers same) (Turbo years had steam ports drilled even on NA heads AFAIK) the valves are.
How do you tell the difference? Dunno.
Old 12 Aug 2014, 08:05 pm
boonie2's Avatar
Any thoughts?
Obviously , if you were quoted $1100 to replace 1 valve its cheaper to get a reman. head , either that or $1100 per valve x 16 - $17,600 valve job , GOD IM IN THE WRONG BUSINESS LOL
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 12 Aug 2014, 08:07 pm
Here is a link to a rebuilder page I found and the changes made to the 2.4 of the years
Rebuilding The Chrysler 2.4L - Engine Builder Magazine
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
TPMS system fault? looking for some how to guidance or projected cost thegreatestjose Wheels, Tires, Suspension 3 31 Oct 2013 11:55 am
No Compression in Cyl 4 WildBronco General Turbo Discussions 3 24 Oct 2013 04:14 pm
Compression ptnut Tech & Performance Forum 12 21 Nov 2011 11:40 am
need some guidance to change spark plugs in my GT turbo BrianW General Turbo Discussions 1 09 Jul 2010 12:38 am
Need Guidance DJ_Rit Turbo Performance 1 10 Apr 2007 11:52 am
