A/C All-In-One Kits
Old 10 Aug 2014, 03:08 pm
Thumbs up A/C All-In-One Kits
So..for the more knowledgeable out there. I scanned and I got no codes. A/C gets cool but not really cold, unless it ran for really long time.
Are the all-in-kits even worth the trouble? For between 25.00 and 40.00, you can get an a/c recharge kits that even includes sealant and oil and is supposed to get the air-conditioning cooler, but do they work?
Way back, when I was driving a '69 Catalina, I tried some of the first kits, which included the Freon (r-12 cans) and a hookup to the low pressure/suction side and they never worked. You could wrap that can in hot wet towels and the can would absolutely get freezing but nothing ever happened.
There have been no problems with my a/c but I dread opening a valve to use a kit and cause more problems. Any one got the word??
Old 11 Aug 2014, 10:27 am
Default Re: A/C All-In-One Kits
well on my pt when the fan was going bad the a/c wouldn't blow cold until I reached highway speeds.
so what I did was fix my rad fan and add an extra fan to blow into the condenser and now blows cold all the time
bought my r134a ez-chill can which had the hose and the freon but due to finacial problems I didn't vacuum the system so I just added the freon and it does blow cold but obly when condenser has good airflow so I ended up puttin an extra fan on the condenser so now its cold inside my pt that even when the outside temp is above the 100*F it starts getting cold enough that I have to turn my a/c off otherwise I can't drive because it feels like its a snowy winter cold
Old 11 Aug 2014, 01:45 pm
I think those kits are a hit or miss thing......gauge was just unreliable.....followed instructions detail by detail but still ended up overcharging my SUV, thus compressor made a lot of noise and was cycling badly like it never did before.....better have it done by a professional who would have pressure gauges on both high & low pressure sides.
Old 11 Aug 2014, 01:49 pm
I do agree on this if you really love your car take it to a good shop to get the A/C system working good, unless you are in a same case like me with some financial issues either you can wait it out or fill yourself. There is many DIY videos out there for filling the A/C or if you have the money go to a shop.
Old 11 Aug 2014, 02:30 pm
cruserdad1976's Avatar
i think it all depends on what is the problem if it just needs some freon go for it there is no reason to suck it all the way donw to just ad freon if it has air in it then you have to vacuem it down the the tube is dirty it needs replaced and if the seals are hard the oil may help but probaly not fix it 100%
Most shops will suck it down recharge it charge you for that and then see if it is cycling you may still ahve to pay for other things
HOW TO VACUUM DOWN & CHARGE YOUR A/C SYSTEM Chromenut Tech & Performance Forum 9 27 Jul 2016 02:05 pm
No charge Hostilgtkb Tech & Performance Forum 1 17 Jul 2013 12:09 pm
2006 AC charge samss Tech & Performance Forum 4 03 Jul 2013 11:14 pm
Turbo Charge? dzyubin Tech & Performance Forum 12 06 Oct 2011 09:57 pm
A/C Re-Charge price? edj8 General PT Cruiser Discussions 6 26 Jun 2010 09:34 pm
