Weird radio
  • 1 Post By Handy_Cruiser
Old 15 Aug 2014, 08:52 pm
Default Weird radio
Ok, so I bought a 2001 PT Cruiser two weeks ago. This is the 2nd one I have owned. WE (wife and I) traded it for a 2008 Town and Country to haul the grandkids. We missed it so much we found one just like it and bought it. We're happy again. Anyway, I'm driving home from Houston, listening to the AM radio and the accompanying static and much to my chagrin when I step on the brake the static clears up. I'm figuring that when I hit the brakes the radio grounds and cuts the static. Anyone have an insight on this? Happy Motoring!!!
Old 15 Aug 2014, 09:02 pm
Handy_Cruiser's Avatar
Default Re: Weird radio
Yep.
Grounding may be the issue. A 2001 should have grounding lead that runs to the back of the stereo head. Pull you stereo head and make sue it is hooked up and hasn't been cut or pulled loose. If it doesn't have one, my suggestion is to run a wire all the way to the engine block where the negative battery cable connects. The metal is the dash may not be grounded well enough to work.
And as a recommendation, you may want to make one of my patented "stereo work stations" so the stereo head can rest comfortably with the cables hooked up while you check out the grounding lead.
rockandroller likes this.
Old 15 Aug 2014, 09:12 pm
Re: Weird radio
This reminds me of the movie
Frequency...
Old 16 Aug 2014, 07:31 am
On my 06 there are ground wires from engine to shock. Mine are broke with no static (shame) but my be yours are causing a problem.
Also if there is a poor signal in the first place this may happen normally.
Mike
Old 16 Aug 2014, 08:03 am
I would try the ground on the dash first. looks a lot better and may work just as good. You can always do the other if it does not clear it up.
Old 16 Aug 2014, 11:11 am
harrym's Avatar
It does appear to be a grounding problem.
Welcome to the forum. There's lots of good info here. And good folks, too!
Harry
2005 Touring n/a - Cool Vanilla with J&J vertical billet grille, PTeazer tail lights, Chrome wheels and Baby Moons.
2007 chrysler base cd radio to chrysler sirus radio swap? peterspt Sound and Security Forum 0 09 Aug 2014 01:14 am
Here's A Weird One.. GTCRUISER2006 General PT Cruiser Discussions 8 11 May 2014 08:39 am
?? WEIRD ?? mdskinner731 Tech & Performance Forum 7 28 Mar 2012 05:22 pm
Weird.... Busa_Powered General PT Cruiser Discussions 12 23 Jun 2011 10:05 pm
