Removed center console, heat control knob problem
Old 19 Aug 2014, 12:13 pm
Default Removed center console, heat control knob problem
Hey folks,
Back a month or so ago, I needed to remove the center front bezel from my dash and move it to the side to install a ham radio bracket in front of the catch all shelf. All cables, etc were still attached.
I noticed the other day that I could only turn my temp control knob to about the 10:30 position before it felt like it was starting bind up. Up until now, I havenít need to turn up my heat so didnít notice anything before this morning. Iím certain this started after I moved the bezel so I could get behind it.
It may be obvious what happened once I get a chance to look behind it. That being said if itís not, what should I be looking for? Iím assuming there is some kind of linkage behind there to a hot/cold gate flap?
ThanksÖTim
Old 19 Aug 2014, 12:23 pm
cruserdad1976's Avatar
Default Re: Removed center console, heat control knob problem
sounds like some how you got a cable in a bind or kinked
Old 19 Aug 2014, 01:41 pm
LionPT's Avatar
Your going to have to remove the bezel & look for the kink.
Old 19 Aug 2014, 02:48 pm
Hopefully I'll get a chance to take a look at it this weekend. Colder weather isn't as far off as I'd like to think it is.
Old 20 Aug 2014, 09:35 am
Mine binds a little in the cold weather but OK in summer.
The catch all tray comes off by itself you know. I installed a scanner there. A little tight but works good.
73
Mike
WB2KKI
Old 21 Aug 2014, 02:48 pm
73
Mike
WB2KKI
Yeah, I removed the catch all tray completely and the back half of my transceiver fits into that. I mounted the radio bracket to the part under the front bezel in front of the tray. I needed to move the bezel assembly away from the dash so I could install the nuts on the bolts holding the bracket. I tried to reach around the dash but my mitts were a bit too big to get the nut on top of the bolt without moving it.
I think I’ll get a chance Saturday to see what I did back there.
Tim KB1MM
Heat control knob not working properly uptosnuff Tech & Performance Forum 5 06 Dec 2012 01:18 pm
Wtb: Center console bezel MOPAR_GIRL Classifieds: Want To Buy 2 15 Oct 2011 02:05 pm
Air- control knob problem, confusing! fuzzyduc Tech & Performance Forum 7 26 Sep 2009 09:00 pm
Center Console Armrest wantaptcruiser Interior Accessories Forum 1 11 Apr 2009 02:21 am
center console lchiwahs Interior Accessories Forum 19 02 Nov 2003 11:26 pm
