cooling fluid used up no leak
Like Tree4Likes
Old 20 Aug 2014, 11:45 am
Default cooling fluid used up no leak
5 days ago my car over heated. they filled it up with coolant and changed the radiator cap. today it happened again and there was lots of coolant mssing with no leak. They checked the oil and it was clean. Left it to be checked further. He said it might be going to the turbo and burning up in there.
ANY THOUGHTS?
BTW its a 2005 turbo 2.4L
Old 20 Aug 2014, 12:33 pm
Default Re: cooling fluid used up no leak
lets start with who is "they"?
Old 20 Aug 2014, 12:34 pm
1 time i had my radiator seeping from the stupid crimped on plastic tanks. the slow leak would evaporate before ever touching the ground. there was no noticeable steam
another time i had coolant leaking out of the waterpump and evaporating before it ever touched the ground. there was no noticeable steam.
in your case they may have simply bled the air out wrong. check the level every time the car cools and top it off as necessary.
you should also check the overflow hose that goes from the radiator to the overflow bottle. if it is not tight enough, it will bleed coolant to the bottle, and then it sucks air back in instead. to make mine for tighter i just clipped 1/2" off the little hose and reattached it to the radiator.
Busted_PT likes this.
Old 20 Aug 2014, 12:41 pm
cruserdad1976's Avatar
what about leaking into the cylenders???? bad head gasket???
Old 20 Aug 2014, 12:42 pm
Rob r u "they" at times than? Can we say that "they" (meaning you) responded in a thread along with them? Or will "they" get upset that I mentioned you could be encluded with them?
some of you must love to start guessing with so little information...me it drives me craaaazzzzy!
ok I am done with my break it is back to work..........
Old 20 Aug 2014, 12:59 pm
ANY THOUGHTS?
THAT is a WILD guess.
Is your engine fan working on both speeds? If yes, have your cooling system pressure tested and go from there.
Old 20 Aug 2014, 01:28 pm
i could certainly be "they". i never bleed mine properly. i just poke and prod the thermostat with a flat head until the air is out, then i drive it, and top it off after it cools. i'm not ASE certified though, so i'm allowed to do it like this.
i wasn't trying to tell him what is wrong, i was simply telling him a few of the places my coolant has mysteriously vanished to.
Old 20 Aug 2014, 01:50 pm
ANY THOUGHTS?
That was what he was asking for He probaly knows that he will never get a 100% answer jst a well this is what happened to me kind of thing
Old 20 Aug 2014, 02:58 pm
Gotta love new members that have a problem and make kamikaze threads.
Old 20 Aug 2014, 03:17 pm
well just like the famous
I just bought a 2006 PT non Turbo
How do i make it do burn outs and get 35 mpg and can i add a supercharger and a 5 speed to it????????????
ya got ta love them post
Transmission fluid leak jcraft General PT Cruiser Discussions 5 18 Jan 2014 02:35 am
transmission fluid leak joeus Tech & Performance Forum 11 11 Jul 2013 09:18 am
Transmission fluid leak! radio4mike General PT Cruiser Discussions 1 28 Jan 2012 07:12 pm
Transmission fluid leak!!! ptguy69 Tech & Performance Forum 0 20 Sep 2011 11:02 pm
autobox fluid leak mopar345 Tech & Performance Forum 4 18 Jun 2010 07:54 pm
