cannot reset the rke help :(
Old 20 Aug 2014, 02:22 pm
Question cannot reset the rke help :(
Hi guys I'm new here and discovered this site here lays my problem and I hope someone can help me. I recently changed my battery on my 2001 pt cruiser the issue is now the remote to lock the doors does not work. ( it did however work before battery change ) I changed the batteries in the fob still no success. When I use the power door. Locks button after about 18 seconds the alarm will sound and I have to manually open the door to silence it. I have been told there is a black box with a button on it under the dash I located this box but there is no button on it I've also been told there is a box under the dash under the drivers side no luck locating it. How can I get this to work again I don't wanna lock my keys in my car anymore which sometimes is a habit lol help please from anyone with knowledge of this would be greatly appreciated in advance thank you
Old 20 Aug 2014, 06:18 pm
Default Re: cannot reset the rke help :(
Have you tried disconnecting the battery again?
Old 20 Aug 2014, 06:54 pm
Are you the original owner or did you purchase used?
Do you know if this is an OEM or after market alarm?
If it is a dealer (rather than factory) installed Mopar alarm, as I installed, then these instructions might help.
Turn the ignition key to on (not start) and back to off, three times ending in off. If this works to toggle the alarm into "valet" mode, you might hear the horn chirp and then see the red indicator on the dash flash in a repeating pattern.
Meanwhile check these dash fuses:
#3 (20 amp), #10 (10 amp), #13 (10 amp)
Tags
remote keyless entry
How to reset Security..... 340x Tech & Performance Forum 11 08 Jun 2017 03:44 pm
Pt cruiser 03 transmission reset 03turbo Tech & Performance Forum 3 02 Aug 2012 06:54 pm
Computer reset chuckd1991 General PT Cruiser Discussions 6 08 Jan 2011 07:27 am
Reset PCM apollobey Tech & Performance Forum 1 10 Oct 2005 01:29 pm
reset computer onyx pt Turbo Performance 19 23 Aug 2004 09:06 pm
