02 non turbo no start/no crank
Old 24 Aug 2014, 11:49 am
Default 02 non turbo no start/no crank
The car wont crank. No click or anything. I checked the starter. It tested good. Battery is fine.
I can jump the starter off the car, it tested fine at Autozone, but when installed it will not jump if i cross the solenoid. I also noticed i have no reverse lights with the key forward and the car in reverse. I have not busted out the mulimeter yet but am on my way to do that now. Any help or suggestions would be great. Thanks.
Old 24 Aug 2014, 01:37 pm
Default Re: 02 non turbo no start/no crank
This is my little cousin's car. It is the 2.4l. From the research I have done through your forum I have narrowed down the issue to the TRS, PCM, or ignition switch.
Update.
12.38 volts at starter. Ground is good and clean. 12.4volts at Pin 30. I jumped the 30 pin to the 87pin and got nothing..... any ideas?
Old 24 Aug 2014, 02:41 pm
Simple system Possible faults
Fuse, Wires, Ignition switch, Relay
Several sensor imputs to the PCM, which is the most complex component.
The PCM grounds the circuit when conditions are not-wrong.
1. BATTERY DISCHARGED OR FAULTY CIRCUIT
2. STARTER CIRCUIT WIRING FAULTY.
3. STARTER RELAY FAULTY.
4. IGNITION SWITCH FAULTY.
5. PARK/NEUTRALPOSITION SWITCH (AUTO TRANS) FAULTY OR MIS-ADJUSTED.
or
6. CLUTCH INTERLOCK SWITCH (MAN TRANS) FAULTY.
7. STARTER SOLENOID FAULTY.
8. STARTER ASSEMBLY FAULTY.
9. FAULTY TEETH ON RING GEAR.
10. PCM DOUBLE START OVERRIDE OUTPUT FAILURE.
CRANK BUT NO START clifford General PT Cruiser Discussions 3 27 May 2014 11:15 pm
crank no start 69charger Tech & Performance Forum 13 18 Sep 2013 07:04 am
crank no start 69charger General PT Cruiser Discussions 1 13 Sep 2013 08:17 am
03 crank no start. spike General PT Cruiser Discussions 3 19 Jan 2012 08:44 am
