EVAP
Like Tree3Likes
Old 27 Aug 2014, 06:21 am
Default EVAP
Ok so has anyone else been having the check engine light with the evap code? I have it on mine and I out the new gas cap on and yes I did buy the gas cap from the dealer. Then had the codes wiped and about 2 days later it came back. So I replaced the charcoal canister. Which I don't recommend because it's not only expensive just for the canister but a pain to get. And I had to drop the gas tank to put it in. Then code erased and a few days later what do u know code is back. Looking for any ideas on what else might be wrong. Thanks
Old 27 Aug 2014, 06:30 am
Default Re: EVAP
Down behind the transmission below the brake fluid resivor is another part of the EVAP, Purge valve?
And if you have an older PT, any leaks letting air into the fuel tank, like a rusted fuel tank fill tube will cause your problem.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 27 Aug 2014, 06:55 am
Default Re: EVAP
Ok I will check for the purge valve next. Which side would the valve be on? The filler tube visually looks find. Yea it's an 03.
Old 27 Aug 2014, 07:45 am
Default Re: EVAP
Here ya go...
http://www.justanswer.com/chrysler/6...rge-valve.html
Old 27 Aug 2014, 08:21 am
Default Re: EVAP
It would really help to know which DTC(s) you had/have?
Your thread title will get future views with other that my have the same issue.
Old 27 Aug 2014, 08:41 am
Default Re: EVAP
Picture of evap
73 Charger SE
01 Sebring flip
Old 27 Aug 2014, 09:40 am
Default Re: EVAP
Originally Posted by Jmcaravona View Post
Ok so has anyone else been having the check engine light with the evap code? ... I replaced the charcoal canister. ... I had to drop the gas tank to put it in. Then code erased and a few days later what do u know code is back. Looking for any ideas on what else might be wrong. Thanks
I had similar problems. Neither a new gas cap nor EVAP purge valve solenoid fixed the problem.
You likely have a failing NVLD (natural vacuum leak detection) valve.
The NVLD also requires dropping the fuel tank as it is located next to the charcoal canister. Consider also changing the system air-filter while the tank is down.
More here about the NVLD and here is a video
Old 27 Aug 2014, 09:48 am
Default Re: EVAP
Yes good thought to bad there is no DTC posted to see if all our help is in the correct direction.
If enough of respond with guessing without more information eventually someone will get it right for the OP?
Old 27 Aug 2014, 10:31 am
Default Re: EVAP
Man, I really love that Red PT, I want a red one...
73 Charger SE
01 Sebring flip
Old 27 Aug 2014, 10:56 am
Default Re: EVAP
Ok I will get my code reader out and let everyone know exactly what it reads. I already had the tank down when I did the charcoal canister sadly. It seems to be a pain in the rear problem with alot of people.
evap error Jmcaravona General PT Cruiser Discussions 2 16 May 2014 09:31 am
large leak evap help souchiem Tech & Performance Forum 11 17 Oct 2013 09:07 am
Evap System - Not Gas Cap dveldt Tech & Performance Forum 5 20 Jul 2013 06:09 pm
Help Troubleshooting the EVAP system geronimo Tech & Performance Forum 6 09 Mar 2009 09:46 am
Trouble shooting EVAP system Blade Tech & Performance Forum 2 04 Apr 2004 09:34 am
