2001 PT Cruiser stalled, the word "head" displayed on odometer
Like Tree2Likes
Old 28 Aug 2014, 06:01 pm
Default 2001 PT Cruiser stalled, the word "head" displayed on odometer
I was going home, luckily got close enough to home and the engine quit. I coasted and stopped in the driveway. On display where the codes appear, was the word "head". When I got out of the car the horn started beeping, I couldn't stop it. I opened the hood and disconnected the battery to stop the horn warning. About 5min. later I gave it a crank and it started but quit a couple of seconds later.
I knew I was low on oil (famous last words), I was getting dings when I turned corners and came to stops.
I changed the oil and filter and tried starting it again and it didn't start.
Have I screwed it up? Or should I say, am I screwed?
Old 28 Aug 2014, 06:26 pm
Default Re: 2001 PT Cruiser stalled, the word "head" displayed on odometer
Here's an old thread where someone had the same problem as your title.
Got a new pt today! Lets figure out whats wrong!
Old 28 Aug 2014, 06:39 pm
My battery is crankin' like a band. I was driving in 3rd gear when the engine quit. I didn't look at the temp. gauge, it might have been overheating, I don't know. I looked under the engine and saw nothing leaking. I checked the gas lines and they look fine. I'm just dead in the water.
Old 28 Aug 2014, 06:56 pm
Handy_Cruiser's Avatar
The honking horn and engine stall after starting for a few seconds sounds like the SKIM has failed. Basically, your PT may not be detected the antitheft chip in your gray ignition key.
Also, on my 2001 PT, the odometer will flash "Head" if turn off the initiation with the headlights on. I usually get a warning tone too. And my PT will also honk if I unlock the door with the key instead of using the fob. And it will honk if I open the hood without the key nearby or in the ignition.
If your battery is down and the lights were left on, it will flash "Head" when you try to jump it. Are you sure your headlights are turned all the way off?
Old 28 Aug 2014, 06:58 pm
LionPT's Avatar
Sounds a little sexual to me...
soonercruiser likes this.
Old 28 Aug 2014, 07:06 pm
I didn't have the lights on and I tried both keys for the car. I was driving the car when the engine died. I have 1/2 tank of gas. It was running fine and quit, I coasted into the driveway. The battery is cranking the engine like crazy but won't fire over.
Old 28 Aug 2014, 07:13 pm
I was out of the car with the car off with the key in my hand when the horn started beeping and wouldn't stop until I disconnected the battery.
Old 28 Aug 2014, 08:50 pm
Did the engine light come on before you saw the "head" display and disconnected the battery?
Old 28 Aug 2014, 09:11 pm
Is there a website where it can tell us what words can appear in the trouble code display for PT Cruisers and what they mean? I was surprised myself one day when I didn't tighten the gas cap and it displayed "GASCAP" in the engine trouble code display.
Old 28 Aug 2014, 10:47 pm
One thing I have learned about the SKIM is that some of the time when it fails the voltage gets too low or there is a possible bad ground. I would check the battery for a dry cell or at least charge the battery first but I agree with Handy_Cruiser diagnosis. On one of our PT Cruisers the battery cell closest to the positive terminal is always running low on distilled water and it has given us trouble with the start and die in three second routine from the SKIM.
"error" on odometer...... ssnobrakes General PT Cruiser Discussions 9 01 Jul 2014 11:13 am
2001 PT Cruiser "hesitates" switching gears hierogrammate General PT Cruiser Discussions 2 13 Jul 2012 12:44 pm
our "new" 2001 Cruiser lachase General PT Cruiser Discussions 8 06 Nov 2010 10:25 pm
Odometer flashes the word "head" feefeethaflee Tech & Performance Forum 20 19 Aug 2009 12:31 pm
