PT's are fussy about replacement alternator????
Like Tree3Likes
  • 1 Post By Busted_PT
  • 1 Post By Handy_Cruiser
  • 1 Post By gwairbrush
Old 29 Aug 2014, 03:38 pm
Default PT's are fussy about replacement alternator????
Are Pt's fussy about their replacement alternators? Aside from personal brand preferences is it absolutely essential to buy a replacement Alt. from the dealer or will any good quality aftermarket be ok?
Old 29 Aug 2014, 03:46 pm
Default Re: PT's are fussy about replacement alternator????
Any quality replacement will work. Life time warranty not always the best. But check around for good reputation. Oem will Cost you a ton. good rebuild shop will do if you got one handy.
gwairbrush likes this.
Old 30 Aug 2014, 01:09 am
Handy_Cruiser's Avatar
The hard part is getting the alternator our from behind the engine. I believe the easiest method is to remove the motor mounts and shift the engine. Here's how I did it:
The "Handy" Alternator Change Out - Motor Mount Technique
mityqwik likes this.
Old 30 Aug 2014, 09:28 am
I would stick to a National Brand rebuilt or not. Other than that I don't think I would pay extra for a Mopar.
Old 30 Aug 2014, 11:21 am
Turns out an intermittent charging problem was nothing more than a loose connection or short at the fusable link.
Old 30 Aug 2014, 11:55 am
Always good to check everything out before spending your money.
Old 31 Aug 2014, 04:56 pm
VNT's Avatar
VNT VNT is offline
How many miles did you get out of the original altenator??
The "Handy" Alternator Change Out - Motor Mount Technique[/QUOTE]
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 01 Sep 2014, 01:42 am
[/QUOTE]
The alternator never quit. I had a chirping sound that I believed was coming from the alternator even after belt change out. Alternator front bearings will sometimes do this. I now believe it came from a misaligned power steering pump pulley that wasn't properly reinstalled when the previous owner had the timing belt changed.
So I guess the "extra" alternator that I have now has about 125,000 miles on it. And it still worked fine when removed for the car.
Old 01 Sep 2014, 03:04 pm
Bench test done.....alternator is fine. Turns out it was a fusible link/wire short causing intermittant charging problems.
So far have 173,000 miles on it...Im second owner so I don't know if its original or not.
Handy_Cruiser likes this.
Old 02 Sep 2014, 08:05 pm
VNT's Avatar
VNT VNT is offline
Hi
Thanks for the feedback guys, always interested to know when other folks have stuff fail so I can guage when I might encounter issues.
My 03 has 137K on it and is still running well.
VNT
Alternator replacement troubles. ericl72 Tech & Performance Forum 2 07 Oct 2013 07:11 am
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
03 gt with bad alternator jacarc1 General Turbo Discussions 5 31 Mar 2010 03:47 pm
Alternator replacement garyerrol Tech & Performance Forum 3 09 Sep 2009 07:18 pm
