New here. average life span of head gasket ?
Old 08 Sep 2014, 05:09 pm
Default New here. average life span of head gasket ?
My 2002 PT has about 86,000 miles on the original head gasket. What is the normal life of the head gasket ? I'm only asking because if it's a good idea to replace it when doing a timing belt. And maybe a radiator. All is well right now, just thinking ahead.
Old 08 Sep 2014, 05:46 pm
Default Re: New here. average life span of head gasket ?
Welcome to the forum. Headgasket is best left alone until such time that it shows problems. Many have gone way past 150k before one is needed.
Old 08 Sep 2014, 07:30 pm
Unless you experience overheating, a headgasket should not need replacing.
What should be changed (in my opinion) when timing belt is done is the thermostat, since you do water pump at the same time....
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? 06turbolite Tech & Performance Forum 8 14 May 2013 09:16 am
03 pt turbo oil in water new head gasket fresh head strokedoutss General Turbo Discussions 7 17 Apr 2013 04:22 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
Radiator cap's life span LoboMX Turbo Performance 10 03 Apr 2007 11:08 am
