Timing belt life span ?
  • 1 Post By quicksilverdon
Old 08 Sep 2014, 05:13 pm
Default Timing belt life span ?
My 2002 PT has 86,000 miles on the original timing belt and water pump. is running fine. When should I replace them ? Also are there certain water pumps to avoid ??
Old 08 Sep 2014, 05:51 pm
Default Re: Timing belt life span ?
We've seen the belt go before 100k but most go beyond that. If we're asked, 100k is a good time to start looking around for a new belt, water pump and tensioner. A good way to save a few bucks is to buy the whole "kit" which comes with everything you need. A good place to start looking is at RockAuto Parts Catalog
Old 08 Sep 2014, 07:27 pm
Age is a factor, too, and high heat areas (Nevada, etc) also shorten the life.
It depends on how lucky you feel.
JoeX likes this.
New here. average life span of head gasket ? rustytoolss General PT Cruiser Discussions 2 08 Sep 2014 07:30 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Radiator cap's life span LoboMX Turbo Performance 10 03 Apr 2007 11:08 am
