Quick Question - Fog Lamp circuit...
Old 10 Sep 2014, 12:20 am
rockandroller's Avatar
Question Quick Question - Fog Lamp circuit...
My fog lamps have never worked, and I just assumed that it was probably the famous multifunction switch issue. The other day I was peeking at the fuse panel and was rather surprised to see that the fog lamp fuse was THERE. Not only was there a fuse there, but the fuse looks like it's good. (I pulled it out, just to be on the safe side...)
Anyway, was just wondering, is anything else on the car serviced by the same circuit? Or does that fuse feed the fog lamps and nothing else?
2004 'Turbo Lite'
Old 10 Sep 2014, 08:29 am
Default Re: Quick Question - Fog Lamp circuit...
I don't know the circuit. but the switch can fail in the off position. Also check plugs for cartosion. One of mine had the plugs to the lamps pulled and killed the plugs. I guess he dodn't know he could pull the fuse.
Old 10 Sep 2014, 09:06 am
According to the 2001-2003 Haynes Manual, the No#8 fuse goes to the multi-function switch, instrument cluster fog lamp switch output and then directly to the fog lamps.
Old 10 Sep 2014, 04:22 pm
They may have taken out the fog light bulbs...
quick tie rod question. coolout Wheels, Tires, Suspension 4 25 Jul 2012 03:32 pm
quick question superjew78 Wheels, Tires, Suspension 15 01 Apr 2012 06:50 pm
Quick S1 question. Morkeste Stage Turbo Kits 26 23 Jul 2011 02:03 pm
A quick question TheDarkAvengerX General PT Cruiser Discussions 9 10 Jul 2011 07:28 pm
Fog Lamp Circuit SILVERONE Exterior Accessories Forum 8 04 Jan 2004 10:40 pm
