ptgt upgrades
  • 1 Post By Jaredcruiser185
Old 11 Sep 2014, 09:12 pm
Default ptgt upgrades
Ok so I have a budget of 2k. What are the best upgrades to start with. I was going to gwt jet pcm off jegs but heard that it can cause damage and then read somewhere else and they are supposed to be great. So im unsure about it
2005 PT Cruiser GT Turbo HO Convertible-
2001 PT Cruiser limited touring-
2011 Hyundai sante fe limited-
1953 Ford coupe-
2007 Dodge megacab 2500 cummins-
Old 11 Sep 2014, 09:48 pm
Default Re: ptgt upgrades
Get a trinity.
Old 11 Sep 2014, 10:17 pm
Didn't I just spend my time answering this?
Originally Posted by NitroPT View Post
2000.00
Tune up,tests,fluid changes -300.00
Stage 1 ECU -300.00
Exhaust system -700.00
Transmission upgraded cooler -100.00
DiabloSport Trinity -600.00
Total with nothing else $2000.00
net gain aprox. reliable 60wHP?
Old 12 Sep 2014, 10:07 am
Any thoughts on the jet performance pcm stage 1 that jegs sells
1953 Ford coupe-
Old 12 Sep 2014, 11:25 am
If you want to achieve the best results without having to experiment on your own may I suggest taking the advise given by some members.
IMHO had I thought that there was a better choice given the perimeters you already set I may have recommended other parts and modifications for you.
Given that you have not even accomplished the basic evaluation of the mechanical soundness of your PT Cruiser IMHO it would be unwise for anyone to suggest things that will increase the power level and potentiality damage your engine or drive train.
The question you asked has been asked and answered at least twice in the last year that I am aware of. Try the search feature a little more?
IMO don't get caught up in titles of after market parts or systems i.e. STAGE 1,2,3, Level 1,2,3, etc. Everyone manufacture including OE try to lure you into their product by the frosting and decoration on the cake. I do it as well with my Performance line of parts.
Forums are filled with LOTS of opinions and very little real testing of data equitation. Many will go of the seat of their pants (butt dynos) or claim foul on a part because it failed to give them the results they thought it would. Mostly because they did not first follow what I recommend to you to do first before upgrading!
Jegs and Summit Racing are both the top aftermarket mail order retail parts distributors and have a great staff that can help you.
IMHO I would go direct to the manufactures and talk to the technical staff about any products you are thinking to buy. You can then compare there information with your research personal experience of end users.
I suggest however to read between the lines with end users on forums. Go to their profile and see who they are threads started and responses on other threads to get an idea of the reliability of information that comes from them.
So lets try this again?
Before anyone upgrades their PT Cruiser you should first see if the PT is mechanically sound. This is what you should do?
*The forums search feature is for dreamers on performance upgrading.
But if you are serious,
What is your goal?
How much can you do yourself? (tools and experience)
The biggest one is $$
How much allotted for the project and in what steps of amounts are available?
If you are not honest and realistic than *
The first steps before upgrading the engines output of any vehicle:
Ascertain general overall engine condition:
Compression test on engine
Leak down test
Cooling system pressure test
Block test
Complete inspection of:
Brake system
Suspension system
Tires and wheels
Normal things to do prior upgrades:
Ignition system Tune up
Change all fluids:
Engine oil/filter
Transmission oil and filter
Brake fluid
Coolant
Old 12 Sep 2014, 11:59 am
Ok thanks and I shouldve clarified earlier but all fluids and filter including trans and egine have been changed less than 500 miles ago. Suspension system has been checked yesterday as I am putting on lowering springs. Turbo leak down was don last week. Compression test has been done when I got the car and have only put 4 k miles on it since then. Brakes. Check cooling system was checked also and a new radiator put on. Brand new rims and tires put on. Thanks nitro pt uve been alot of help and I shouldve clarifies that id done thes things earlier on.
NitroPT likes this.
1953 Ford coupe-
Old 12 Sep 2014, 12:12 pm
Skip the JET! nuff said!
You may want to invest in an ULTRA GAUGE?
UltraGauge OBDII Scan tool & Information Center
I recommend that you start to shopping for a STAGE 1 PCM
The top recommendation you will find is FWD Performance
You will need to call FWD for price and current availability.
https://www.fwdperformance.com/Store/
IMHO DO NOT BUY from any other source? That includes former PT owners selling them or used ones from any source other than FWD Performance.
BTW feel free to visit my profile.
Old 14 Sep 2014, 06:49 pm
vipergts's Avatar
60WHP with those mods?...Not happening..
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
Old 14 Sep 2014, 06:52 pm
2000.00
Stage 1 ECU -300.00
Exhaust system -700.00 = 15-25+
DiabloSport Trinity -600.00 With a good calibration 20-30+
Maybe I should have been conservative and said 40-60whp But I did say aprox.
It all about compatible upgrades and a good calibration to tie them all together.
Old 14 Sep 2014, 07:16 pm
Just so you we don't debate back and forth. If you really read and I mean read the response you can see that it very possible for the gain I mention.
And if you can not figure it out pm before responding.
ptgt vs 350z mattsptgt PT Cruiser Videos 10 13 Sep 2011 07:30 pm
cam upgrades coach96 Tech & Performance Forum 0 07 Aug 2009 03:14 pm
my PTGT has cancer vghnnthn2187 Turbo Performance 3 01 Dec 2008 12:03 am
PTGT-Autostick. You use it??? Teekypt Tech & Performance Forum 14 08 Nov 2008 10:51 pm
Might be buying an 04 ptgt! Dirk_Gently General PT Cruiser Discussions 20 11 Sep 2008 09:33 pm
