DASH GOES CRAZY
Like Tree2Likes
Old 15 Sep 2014, 09:35 am
Default DASH GOES CRAZY
My dash started to act up today. The warning lights flashed on and all the gauges went crazy. The car ran fine during all this and no engine light. Now it is working again. I looked at the threads and looks like other people had this problem but no common fault. Anything new on this and should I start at the TIMP which I think is same as body control module or cluster, that does not look easy to remove. Any new info would be appreciated.
Mike
06 PT standard edition 91000 miles.
Old 15 Sep 2014, 10:16 am
Default Re: DASH GOES CRAZY
I'd start with the grounding wires including the battery. Things like that happen sometimes when the battery gets weak or is loosing good connections to ground.
Old 15 Sep 2014, 11:40 am
Just got back in from doing that. I pulled the timp pulled all the connectors and reset them set all the fuses and pulled the battery wire on the timp and cleaned the contacts and put some dielectric past on it.
The battery is fairly new but pulled and cleaned all the battery connections as well as the chassis ground. will see what happens from here. The sad part is it looks like a common problem but not a common solution.
Going to take it for a ride now hope I didn't cause any other problems but the car did start and the dash so far is still working.
Thanks\
Mike
Old 15 Sep 2014, 12:12 pm
cruserdad1976's Avatar
you might get a code that is for Battery was discinected i actually never got that code but others have
Old 15 Sep 2014, 12:18 pm
Thanks\
Mike
I had the same issue when I needed a new battery cable. The issue was the ground. All connections were clean and had dielectric grease on them but the cable itself was bad. It looked fine on visual inspection. If cleaning the connections worked for you you're probably fine.
Old 08 Oct 2014, 02:45 pm
Just an update. It's been about three weeks now and so far so good. SO maybe I did good. For now I will assume it's working but I know these problems can return months later but hope what I did can help someone else and give another tool to repair to this problem, which I understand is more common than not.
Old 08 Oct 2014, 03:10 pm
Mike
My 03 did the same thing after getting a water bath from low spot in the road which was now a pond... It never happened again.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 17 Oct 2014, 10:43 am
Update:
Well guess my luck it didn't last. Was out with the PT today and all the warning lights came on and quickly went off.
My next step is to replace the ignition switch as my internet research seems to lead me.
Any other ideas are appreciated.
Old 17 Oct 2014, 11:01 am
If you ensured connections are clean and tight, ignition switch is another frequent culprit...
Hope that's it....
Old 24 Oct 2014, 11:43 am
Mine started that a few years ago. Tracked it down to the switch and having too many keys on the keyring.
Started driving it with just the one key in the ignition and it hasn't happened since.
Easy enough to try...
rockandroller likes this.
You may think im crazy..... pluminator Tech & Performance Forum 13 03 Apr 2013 09:09 pm
Am I crazy? Busa_Powered General PT Cruiser Discussions 15 16 Dec 2012 09:21 am
Crazy a$$ GT PeteyGT General Turbo Discussions 3 25 May 2012 07:40 am
am I crazy Alini General Turbo Discussions 24 20 Nov 2004 08:23 am
