2007 Limited Idling Rough. Need help!
Old 15 Sep 2014, 09:44 am
Default 2007 Limited Idling Rough. Need help!
I have a 2007 Limited that the timing belt broke on. Now it idles rough but seems of when driving it. I had two codes registering, one was a crank shaft sensor which I replaced and the other was intake manifold air leak. I cant seem to find a leak. There looks to b only a couple vacuum hoses on the intake. One runs to the brake booster and the other one to the valve cover I believe. When either one is removed it idles better and when hooked back up it wil stall the motor out. Not sure what to do next.
Old 15 Sep 2014, 10:19 am
Default Re: 2007 Limited Idling Rough. Need help!
http://www.ptcruiserlinks.com/forum/...ad-please.html
WELCOME and Forum Rules
Old 15 Sep 2014, 11:45 am
LionPT's Avatar
Originally Posted by Diebold40 View Post
...the other was intake manifold air leak. I cant seem to find a leak.
Get some starting fluid & spray it around the entire intake manifold while engine is running...if idol changes than you need to replace the manifold gaskets.
Old 15 Sep 2014, 12:14 pm
cruserdad1976's Avatar
you knwo this sounds like you may ahve the timing off 1 tooth this is oretty much what happens after a timing belt change they think it is lined upa dn in time but in =reality its 1 tooth off and this is the symptoms rough idel and probaly lousy gas millage
Old 15 Sep 2014, 07:13 pm
Dad is all over this one. Here are some good pics of the belt timing.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Old 16 Sep 2014, 08:18 am
First someone needs to check the timing. As far as a possible vacuum leak google Scotty kilmer how to check for vacuum leaks with a cigar. AKE simple do it yourself smoke test.
Good Luck
Mike
2001 PT surging and rough when idling Sue Tech & Performance Forum 8 31 May 2016 11:09 pm
misfire/rough idling with a/c on Dave92 Tech & Performance Forum 5 03 Aug 2014 09:50 pm
05 PT - no air during idle, rough idling. ptisalemon Tech & Performance Forum 4 31 Oct 2011 10:44 am
PCV Valve? Idling Rough/High MattTee Tech & Performance Forum 4 17 Jan 2010 06:25 pm
Rough idling, backfiring, hesistation DJR General Turbo Discussions 19 08 Feb 2006 10:05 pm
