Cooling system flush
Old 15 Sep 2014, 10:57 am
Default Cooling system flush
What is the best way to flush the cooling system your self at home.
Old 15 Sep 2014, 11:16 am
Default Re: Cooling system flush
How to Flush Your Vehicle's Cooling System - For Dummies
Old 15 Sep 2014, 11:18 am
cruserdad1976's Avatar
well this will get a LOT of dirffrent replys but for me
I drain the system put in a bottle of supper flush and run the car to work and back which is like 200 miles
then i drain that out and refill with stright water and runt that for a hour or so then drain that out at that point i refill with Zerok G-05 and water 50/50 replace the theromastt and start the car get it hot bleed the air and hope im good to go
some say use distilled water but i ahev a water softner and a rainsoft system so i just use my houise water and i dont think you 100% ahve to go with HOAT there is a HUGE debate i do cause I can get it at NAPA and its a once every 2 year thing
you beat me to it CREWZIN
gurgling in cooling system mispep Tech & Performance Forum 6 03 Jul 2019 11:56 am
More Cooling system questions euphonium_john Tech & Performance Forum 2 22 Apr 2014 11:10 am
Help with cooling system!! Osufan64 Tech & Performance Forum 3 29 Oct 2013 01:09 pm
Cooling system problems scubasquid Tech & Performance Forum 19 01 Jan 2013 09:48 am
cooling system ? cllwyrc Tech & Performance Forum 6 25 Apr 2010 10:35 pm
