Dumb question: Need help
Like Tree10Likes
Old 15 Sep 2014, 11:25 am
Default Dumb question: Need help
I have. 2008 pt non turbo
Does my car have front and back calipers or just front?
Im about to buy some caliper paint and need to know.
Also how many cans per caliper?
Im really not even sure what kind in gonna get yet or a kit.
Im gonna try to use brake cleaner and then paint them.
Old 15 Sep 2014, 11:40 am
ptprice's Avatar
Default Re: Dumb question: Need help
You'll see the disk and caliper thru the your slotted wheel if you have one, or if you don't take a rear hubcap off to see. If it isn't disk in the rear it'll be drum. All PTs were disk in the front. Take a peek. ptprice
Old 15 Sep 2014, 11:42 am
You mean you can't tell if you have 4-wheel disk brakes or not? If not, I suggest to get someone with a little more experience to help with your project. You'll get a better job if the main part of the caliper is taken off and done off the car and from what I'm reading, you don't want to do that by yourself.
boonie2 likes this.
Old 15 Sep 2014, 11:47 am
LionPT's Avatar
Rear Drums were standard, Rear Calipers were an Option. Pull off a rear tire & look.
Old 15 Sep 2014, 11:54 am
Lol. No I dont want to do it by myself, I know, im a newb.
I dont want to have them teken off to paint them because I think you have to bleed the brakes afterwards right?
I just bought a set of 15" rims. Im going to the tire shop right now and while they dismount my tires off the stock steelies/hubcaps to mount to my new rims thats when I plan to paint the calipers
Old 15 Sep 2014, 12:15 pm
cruserdad1976's Avatar
the PT si a pretty simple caliper change yes you do ahve to bleed the lines but it will be a way way better job and last a lot longer
Old 15 Sep 2014, 02:24 pm
Handy_Cruiser's Avatar
Rear disc brakes will look like this except the stock calipers will likely be rusty brown instead of red. Also, if your PT has ABS, there's a good chance you have rear disc brakes.
Old 15 Sep 2014, 02:51 pm
Even if you have grum brakes in the rear, I believe you should paint them or at least apply a rust treatment,I use NAPA 765-1232, for the simple reason if you let them rust the iron that falls off will cause the chrome wheels, if you have them to pit then peel. The bare iron will also cause discoloration on aluminum wheels.
If your rear brakes are drums I recommend you pull the drums and also treat the groove on the inside edge of the drum and while ther check the pads to make sure the glue that attaches them is not failing.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 15 Sep 2014, 03:31 pm
...or the drum brakes can always be covered up.
10" aluminum disc drilled to match the front rotors placed over the drum before the wheel goes on.
JoeX and LionPT like this.
Old 15 Sep 2014, 03:54 pm
Or----
If you have rear drum brakes, you can always upgrade the "Handy" way.
The Handy Rear Disc Brake Upgrade
And here's the same thread without all the banter in between the good stuff.
http://ptcruisernetwork.com/forum/in...pic,688.0.html
cruserdad1976 likes this.
REALLY DUMB QUESTION!!!!!!! 2002ptcruiserwoody723 Tech & Performance Forum 10 14 Nov 2013 01:34 pm
Dumb Question L2fish Tech & Performance Forum 1 07 May 2013 07:54 pm
Dumb question #1 GT Kruzr Turbo Performance 5 22 Apr 2004 11:13 pm
yet another dumb question GTcamster General Turbo Discussions 18 22 Apr 2003 06:47 am
dumb question of the day !! bobs turbo pt General PT Cruiser Discussions 7 21 Feb 2003 08:01 am
