2004 PT touring won't start!
Old 15 Sep 2014, 08:51 pm
Default 2004 PT touring won't start!
2004 PT won't start.
Battery taken in and checked good. Replaced starter, Replaced Cam Position Sensor, Checked all wires and relays, have power to all applicable power points and all wires ring good. Checked fusible link, good. Bought a replacement PCM, immobiliser and ignition switch with key, installed all at the same time and still nothing! Reinstalled all original components and bought a new coded key, no help! I have no fault codes when doing the three switch code check. I get all other electrical. The red light on the console comes on when key is turned, goes out and then comes on steady. It won't turn over at all! I tried jumping the starter relay and it will give one quick crank then nothing. It's as if there is a problem with the security, but the new PCM, immobilizer, ignition switch and key should have overcome this. Any ideas? Would a crank position sensor cause this to happen? I would think that would throw a code? Any help would be greatly appreciated!
Old 16 Sep 2014, 08:12 am
Default Re: 2004 PT touring won't start!
I replaced my PCM from a place in Florida and got the same results after it started one time and then the battery was disconnected. Red light came on and thats Security Key Programming. It was returned.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Factory CD/radio (2004 Touring) rockandroller PT Pass It On 2 23 Nov 2014 03:16 am
02 pt touring wont start dl3405 Tech & Performance Forum 10 22 Aug 2013 03:42 pm
Like new very low mil 2004 Touring for sale Rolf Classifieds: For Sale/Trade 1 05 Sep 2012 08:33 pm
2004 PT Touring Turbo parts FS InfernoPT Classifieds: For Sale/Trade 3 06 Oct 2009 08:09 am
2004 PT Touring Edition PTCumming Tech & Performance Forum 11 14 Oct 2003 10:36 pm
