radiator ddrain plug 06 pt
Old 20 Sep 2014, 10:30 am
Default radiator ddrain plug 06 pt
OK I give up! How do you use the radiator drain plug on a 06 PT. I turned it I think as far as it goes and nothing. Being a whus I did not force it or try to pull at it. I just pulled the lower hose and goter done. It would be nice though to know for next time.
THANKS all for all the help so far!
Mike
Old 20 Sep 2014, 10:36 am
Default Re: radiator ddrain plug 06 pt
If the bottom of the radiator isn't clogged up, turning the rubber pet-cock 1/4 to 1/2 turn and pulling it out about an inch should start the coolant flowing out. It doesn't come all the way out.
Old 20 Sep 2014, 12:32 pm
Ok, you have to pull it out. Kind of figured that but didn't want to try it. Pulled by hand but sure it needed more help from a pair of pliers and didn't want to push my luck.
Thanks!
radiator drain plug wood38 PT Cruiser Convertible Forum 2 18 Aug 2013 01:40 pm
Radiator drain plug bogaz Tech & Performance Forum 12 11 May 2012 01:54 pm
can't find radiator drain plug notarobot General PT Cruiser Discussions 1 28 Mar 2010 10:40 am
How to replace radiator drain plug? hotdog789 Turbo Performance 2 22 Feb 2010 11:57 pm
Radiator drain plug Mapper Tech & Performance Forum 16 15 Jul 2009 08:06 pm
