Coolant Mystery
Old 20 Sep 2014, 09:17 pm
Default Coolant Mystery
So, lately, my 2006 PT Cruiser has been leaking coolant unto the back of the engine bay from the area of the reservoir without ANY appearances of the source of the leak. It appears to be over full (coolant reservoir) even when the engine has cooled off. I am not over heating, the oil smells, looks normal, and was low. None of the radiator hoses are wet or appear damaged.
My biggest fear is a head gasket problem, but I really am not sure what's going on with it. I first noticed this issue today when I came up to a stop sign I smelled coolant. Then when I got to work I looked under the hood and noticed a drip and the firewall near the reservoir was damp with coolant. My observation was that the coolant was overflowed. I rechecked it after work and even with the even cooled the amount of the coolant remained. I was not able to check if there was any coolant in the radiator itself.
Any idea's, past experiences, or tips to help me keep this car alive!? O; PS. Non-Turbo. Thanks again!
Old 20 Sep 2014, 10:20 pm
Default Re: Coolant Mystery
How many miles on the PT Cruiser?
Is it overheating?
Has there been anything problems lately with the engine?
Has the engine ever been taken apart?
Old 20 Sep 2014, 10:38 pm
Also check for small coolant leaks in the radiator, hoses, thermostat housing, heater hoses, etc. Check for white powder residue from dried coolant anywhere where coolant might leak out. Also check your radiator cap.
Not having a completely sealed coolant system will allow the boiling temperature point on your PT Cruiser to lower but it's probably getting just hot enough not to overheat the engine, but hot enough to get the water to expand and overflow going out the vent hose after filling up the reservoir tank .
Old 21 Sep 2014, 06:56 am
LionPT's Avatar
You need to do this before you drive it again. Have a radiator pressure test done, also combustion gas leak detector test done...checks for gases in fluid (Blown Head Gasket).
Old 21 Sep 2014, 08:32 am
The above test is a great way to check your head gasket.
A good way to locate a coolant leak is buy a dye kit. Comes with dye, classes, and uv penlite. Not very expensive. Put the dye in the cooling system take a ride and when you come back check for leaks with the kit. Should show the source. Good Luck!
Old 21 Sep 2014, 11:21 am
I've seen different ways of doing this. After the night the reservoir went back down, but still way over the HOT marker. And fluid returned into the Radiator.
I'll do the test and report back.
Thanks for the intel.
Old 21 Sep 2014, 11:49 am
You should also check that the hose to the tank is tight on both ends and doesn't have any holes. If loose just cut a half inch off and reinstall.
When this is loose it will push coolant into the tank when hot but suck air when it cools. Until it starts to heat and overfill the tank.
Old 21 Sep 2014, 12:55 pm
Annnnnnnnnnnnnnnnnnnddddddd deer.
Well..this is great.... driving to church this morning nailed a deer, cracked the radiator. I'll have to find out if my insurance company will do anything. I got it through the dealership and already having 'problems' with them. JD Byrider. And the Insurer is Ohio Indemnity Company.
Old 21 Sep 2014, 01:45 pm
You have full coverage insurance?
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
2001 coolant loss mystery zip Tech & Performance Forum 40 29 Jan 2013 01:17 pm
MYSTERY jfahey General PT Cruiser Discussions 3 07 Jan 2012 11:44 pm
More mystery..... AquamarinePT Tech & Performance Forum 3 15 Jul 2009 07:38 pm
Mystery Oil Mel K Turbo Performance 5 21 Aug 2005 09:34 pm
