Loss of Compression
Like Tree2Likes
  • 2 Post By NitroPT
Old 23 Sep 2014, 05:37 pm
Default Loss of Compression
I have a 2002 PT, cylinder #3 has only 50lbs. of compression. It has a major skip at idle , when the rpms go up it appears to smooth out. This appeared to come on slowly i e check engine light came on and off until I felt the skip. I took it to get the code checked , that was when they said we had a skip in #3.
I took it to a shop , thats when we found out about the compression. Check engine light stays on all the time now and it beeps it we are at a redlight. Once we get to speed the beeping stops.
Ideas??
Old 23 Sep 2014, 06:13 pm
Default Re: Loss of Compression
Originally Posted by hotdog3142 View Post
I took it to a shop
Ideas??
YES!
Find a better qualified shop!
Re-do a proper compression test and you can post results
Follow up with a cylinder leak down test and you can post results.
Than before you do the tests or reply may I suggest for you to read this.
Thank you and Welcome to the forum.
PT problems read this FIRST
Compression Papa2448 General PT Cruiser Discussions 12 10 Jan 2016 12:15 am
compression loss ohioptdriver Tech & Performance Forum 15 04 Nov 2013 10:45 pm
No Compression in Cyl 4 WildBronco General Turbo Discussions 3 24 Oct 2013 04:14 pm
compression psi moonshinehd Tech & Performance Forum 7 27 Apr 2012 10:03 pm
Compression ptnut Tech & Performance Forum 12 21 Nov 2011 11:40 am
