engine question?
Old 25 Sep 2014, 06:07 pm
Default engine question?
what is the difference from 2003 and 2005 2.4 turbo engine, what chrylser did to that the engine is from 215hp to 250? i saw some has plastic intake compare to the metal ones,
Old 25 Sep 2014, 06:10 pm
Default Re: engine question?
Not 250, 230.
Larger injectors in 2004 - rating went to 220.
composite intake in 2005, went to 230.
Do a search - there are reports Chrysler underrated the turbo horsepower in the PT GT and SRT4.
Old 25 Sep 2014, 06:24 pm
The intake changes from the aluminum to composite was long believed and reported on auto forums to be a power increase part. However resent testing along with understanding what Chrysler did to increase the power rating has been shown to have been the PCM programming. The fuel injector size increase was to support the increases in fuel demands to make the higher engine output safe and reliable for a stock engine. The increased fuel injector size had a safe duty cycle operating range set by Chrysler power plant engineering and PCM program departments. The size of the pre 2005 injectors technically could have supported the 230HP engine output of later years second generation PTs but at a cost of increasing the duty cycle to 95+%. Most Performance programmers will stay at about 80% maximum before suggesting an increasing in fuel injection size and OEs generally are very conservative at up to about 70%.
Old 25 Sep 2014, 07:00 pm
That's correct. The turbo light got the bigger injectors too. It's only rated at 180 HP. It got the plastic intake as well as the 05 GT, and you guessed it! No HP gaines. 230 was a product of the pcm programming as with the stage 1! Even the cam shafts are all the same. Even the N/A has the same cams as the GT. The wonders of programing is responsible for it all.
Old 26 Sep 2014, 06:44 pm
thats awsome info, so by what i read, best bet is the replace the injectors and get a programer for the pcm will increase meabe not to 230hp, but pretty close.
unless i replace to whole turbo with the cams,,
Question about my engine. PTCruiserNoob Tech & Performance Forum 10 24 May 2013 08:16 am
Engine Question. Alex_Clarke General PT Cruiser Discussions 32 17 Jan 2011 05:02 pm
Engine question hurlermom101 General Turbo Discussions 2 04 Aug 2010 11:38 am
Gt engine question careyk General PT Cruiser Discussions 1 21 May 2008 01:36 am
Engine Question! b0b88 Tech & Performance Forum 7 03 Apr 2008 05:27 am
